Outdoor Wood Furnace HELP!!!! - HVAC - DIY Chatroom Home Improvement Forum
Old 11-26-2008, 12:12 PM   #1
So I have an outdoor wood furnace that i just starting using last night. It wasn't fun but i am new to it. My question is should both circulator pumps be running constantly? I have two, one that keeps the existing boiler hot and the pump that runs from the outdoor furnace.
sgruver78 is offline   Reply With Quote
Old 11-26-2008, 01:07 PM   #2
Rewards Points: 150
Are you running a water to water heat exchanger? What type of outside furnace and what is the aquastat set to temp wise?
Gary
Gary_602z is offline   Reply With Quote
Old 11-26-2008, 01:15 PM   #3
i have a water to water heat exchanger and i have it wired to run constantly because someone told me to but i didn't know if there is another way of doing it so it just kicks on at a certain time.
Old 11-26-2008, 02:14 PM   #4
Rewards Points: 150
If you have an aquastat on the wood heater that will control your draft to keep your water from the outide at a constant temp. Your circ. pump from the outside furnace should run all the time.
Gary
Old 11-26-2008, 04:11 PM   #5
thanks gary. do you think its a problem that i keep the pump running on my existing furnace. i am not too familiar with pumps and i didn't know if it would burn out quickly. thanks!
Old 11-26-2008, 04:44 PM   #6
Rewards Points: 150
Sorry but I don't really know how your boiler system is set up, but I am sure someone will chime in.
Gary
Old 11-26-2008, 07:08 PM   #7
Rewards Points: 150
This should give you a rough idea.
http://www.maximheat.com/systemexistingboilertech
Gary
Old 11-26-2008, 09:05 PM   #8
Do you have an hydronic system with an existing boiler in your house? Or do you have a forced air system with a heat exchanger coil in the ductwork above or below the furnace?
hoistdoctor is offline   Reply With Quote
Old 11-26-2008, 09:19 PM   #9
Whatamess
I had a water furnace once and the pump only circulated the water when the thermostat called for heat. When the thermostat cut out the pump cut off and the fan ran until the limit switch cut it off.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
