-   -   Outdoor condensate pump tubing (http://www.diychatroom.com/f17/outdoor-condensate-pump-tubing-158736/)
Unclev 10-02-2012 05:45 PM
In August I had a new heat pump installed with a new air handler located in the basement. The installers left about 4 feet of the clear tubing coiled up just laying on the ground along side the heat pump pad. This was done at my request because at the time I didn't know if I wanted to collect the water in a bucket for watering purposes or not. At this point I decided I do not. The AC portion will not be running in the winter but the tubing is still totally full of water. I live in Pennsylvania and it will go way below 32 degrees this winter and freeze the water in the tubing that is located outside. Is this OK? Should I evacuate the water before winter? If so how do I do that? Also I was told that I could just bury the tubing in the ground into a french drain. If that is done will I have to worry about future blockage? Any and all ideas on what to do to make this look aesthetically better and functional would be greatly appreciated. Thanks Uncle V.
ben's plumbing 10-02-2012 09:16 PM
blow out water that will be fine till spring....
Flyers28 10-11-2012 07:49 PM
Is there a humidifier hooked up to the system. If so there will be water in that tube all year long. We always run our condensate lines into sinks or some where else inside the house if a humidifier is present.
bobelectric 10-11-2012 10:27 PM
The inside unit is where you need to worry about the condensate.Outside ,just in defrost cycle.
