Outdoor Compressor Not Turning On - HVAC - DIY Chatroom Home Improvement Forum
Old 07-04-2010, 11:09 PM   #1
Rewards Points: 125
Outdoor compressor not turning on
Noticed that the AC wasn't keeping up with the setting on the thermostat so went outside and found the compressor wasn't running. Went back inside and checked the breaker and it didn't trip, so went back to outdoor disconnect at the compressor and measured voltage and was getting 230V at disconnect. Unit is getting power but not cutting on. Noticed a burnt smell around the compressor, and it's been running longer than normal due to high temps in area.
Anything else that I could check before calling HVAC contractor?
Thanks,
Michael
marriedmanw is offline   Reply With Quote
Old 07-05-2010, 10:40 AM   #2
Rewards Points: 125
Problem solved. Turned out to be bad capacitor. Replaced for $20 and back to staying cool.
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 05:47 PM
Pluming Hot Water Turning Cold - Help! kissiffer4 Off Topic 1 01-14-2010 06:00 PM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 09:07 PM
turning off water Jack Hass Plumbing 1 02-03-2007 10:00 PM
Turning valve at water meter KCnorthernCA Plumbing 15 10-23-2006 12:35 AM
