Our Lennox G24M4/5X Fails To Ignite - HVAC - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 10:14 PM   #1
Our Lennox G24M4/5X fails to ignite
Our Lennox G24M4/5X fails to ignite. Thermostat is operational, & activates the combustion air blower; also changes the blink pattern of the LED; When Thermostat is off, LED blinks constantly on/off. Once Thermostat is turned on LED blinks 4 times then shuts off, this repeats every 5 seconds. Manual fails to provide diagnosis for 4 blink LED fault message. Suggestions appreciated.
Ucla61 is offline   Reply With Quote
Old 11-29-2010, 10:21 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
4 flash is typically high temp limit, have you replaced filter, opened all register, check evap coil for being plugged
hvactech126 is offline   Reply With Quote
Furnace fails to ignite now and then... diitto HVAC 7 11-23-2016 04:19 PM
Lennox Furnace 80UHG3 Won't Ignite KeithGP HVAC 8 03-22-2014 11:22 AM
Lennox 80MGF3-75A-3 Won't ignite SAMUEL58 HVAC 7 12-10-2010 09:58 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
Lennox furnace fails to ignite Kool Breese HVAC 1 01-05-2009 11:58 AM
