OTR Microwave Ducting - HVAC - DIY Chatroom Home Improvement Forum
Old 04-06-2012, 01:28 AM   #1
Hi, thanks for your time. I tried searching for "exhaust hood duct" and read thru the ~20 or so threads. I am attempting to install an OTR Microwave/Exhaust and had some questions about the ducting.
The OTR Microwave has a built in damper.
I have 2- 90 Elbows and the semi rigid ducting show in the pictures (7" diameter). I also have a 3.25"x 10" to 7" adapter.
Pics:
https://picasaweb.google.com/Jim.Mac...eat=directlink
There is a wooden beam about 1" from the duct if it comes straight down from the roof vent, and I am worried that the exhausting air might pose a fire hazard. 1. Will this be a hazard if I install the ducting as I had planned?
2. If it is a hazard, how should the ducting be run instead?
Thanks for your time!
jimbriam is offline   Reply With Quote
Old 04-06-2012, 09:05 AM   #2
Rewards Points: 236
i am no pro. but it looks to me, that if that vent gets hot enough to be a fire hazard = that vent is the least of your problems. that vent, when in typical use, will not get hot enough that you couldn't touch it.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
jimbriam (04-06-2012)
Old 04-06-2012, 09:41 AM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
The heat required to start a fire with any of that material will never be reached with the duct work your installing.
Non issue IMO.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
Replacing a OTR Microwave that Vents Outside lydiainflorida Appliances 1 03-29-2012 02:03 PM
over-the-range microwave problem aumanpj Appliances 6 12-04-2010 05:46 PM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 10:30 PM
OTR Microwave installation bfarber Appliances 3 12-22-2008 07:55 PM
Microwave Outlet Move Rsinc25 Electrical 3 11-22-2007 03:46 PM
