Original Problem To Beckett Burner Question.. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-13-2010, 03:23 PM   #16
An old Tradesmen
Rewards Points: 7,338
Yep. 2 stage will energize both the Y and W.
You need a dual fuel thermostat. or a dual fuel add on control.
And with the set up you already have. no real need to add more controls to it. Get a dual fuel thermostat.
Old 01-14-2010, 04:07 PM   #17
I talked to the guy that installed the unit... He said I don't need a dual fuel stat... He said he phased them together (Transformers) so it would not as you said buck so should work... Does this sound right...
jmhai is offline   Reply With Quote
Old 01-14-2010, 04:25 PM   #18
An old Tradesmen
He apparently doesn't know what a dual fuel thermostat or dual fuel control does.
If he phased them (yes, it is possible) then you wouldn't have seen smoke. So he probably did that wrong also.
its an isolation relay that is used to prevent transformers from bucking each other. And most thermostats have that built into them for many many years now.
A dual fuel thermostat prevents the furnace and heat pump from running at the same time. Other then during defrost. And can also be set to lock out the heat pump at X temp and make the furnace only run instead.
You need a dual fuel thermostat or control. Or, a lock relay system made up for it.
Oil Burner Question timlaptopm101 HVAC 2 05-31-2008 05:02 PM
Question about air handler blower problem whlnut HVAC 2 08-27-2007 01:01 AM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 02:04 PM
Wood Burner Installation Question? fisher501 HVAC 1 12-22-2005 09:29 PM
