Orifice Change Or Not ????? NEED SOME HELP !!!!!! - HVAC - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 09:39 AM   #1
Orifice change or not ????? NEED SOME HELP !!!!!!
I am getting a new (model # CAPF3636B6) Goodman Evaporator Coil 3 ton 13 SEER does both R-22 or R-410-A. My compressor is a Goodman CKL36-1D it's a 3 ton 10 SEER R-22 unit. My question is do I need to change out the standard orifice with this kit ( Danfoss Orifice #73 13 SEER Orifice Kit - 3 Ton R-22 ) only $ 6.99 over at alpine air. I know that it is for the use of different tonnage units (MIXED), is it also for the different SEER ratings 10 vs 13 ????? Might be a dumb question I just don't know!!!
bullmastiff135 is offline   Reply With Quote
Old 04-16-2011, 10:11 AM   #2
An old Tradesmen
Rewards Points: 7,776
More like you should use a TXV.
Old 04-16-2011, 04:56 PM   #3
Well from what I have found out the guys over at alpine air said I need this, I didn't ask why. But when reading about what it is used for , used when different tonnage is being used not the SEER rating difference. They did say I don't need the TXV kit but I need the orifice kit, I guess I will just order it
Old 04-16-2011, 04:59 PM   #4
An old Tradesmen
Order it. But it won't work as good as the TXV would, and won't remove moisture as well as the TXV would.
Old 04-18-2011, 10:12 AM   #5
Alco EK163S
Well I was going to add a new Refrigerant Filter Dryer I think that might help
Old 04-18-2011, 05:30 PM   #6
An old Tradesmen
Filter drier has nothing to do with removing humidity from your house.
Wrenches needed to change blade in mitre saw? Evil Scotsman General DIY Discussions 10 04-01-2011 12:00 AM
How to I change the filter. kadisa Appliances 1 03-31-2011 07:57 PM
Discussion on Contractor Estimates/Contracts ARI001 General DIY Discussions 19 11-25-2009 10:47 PM
How hard is it to change locks/tumblers? abefroman Remodeling 4 03-04-2009 08:33 AM
Changing potty. Do I need to change the flange out? tarheelblue Plumbing 9 09-04-2008 11:41 PM
