Options For A Stuck Compressor - HVAC - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 03:16 PM   #1
Options for a stuck compressor
Hello,
I've been reading this site for a while and decided it is time to make my first post.
Compressor on the outside AC unit stuck. HVAC tech just attempted to put on a hard start kit (I think it was a TT6, didn't find it on Grainger's site, I'll check when I get home). That didn't fix the problem. His next two options are to replace the compressor or replace the whole system. The system probably does need to be replaced, but I'm in the middle of a short sell (held up in the banks at the moment). I have no intention of dropping $3000+ into this system.
So, who has a suggestion on a cheaper method to get this going? I am considering one of the more powerful Suppco kits (SPPE8) to get it going. Perhaps a hammer to the compressor. Are there any ways to attach external motors to assist? I'm open to any suggestion that is south of a grand at the moment.
msummers80 is offline   Reply With Quote
Old 06-04-2010, 03:23 PM   #2
You may also want to check the voltage at the compressor during attempted startup; the problem may be in your house wiring.
If the voltage stays high enough, as a last resort, and the motor capacitor may not like this, put 360 vac or 480vac into the compressor for a very short interval using a 5 kw or 10 kw boost transformer or other means. This gives you ~2.3x or ~4x the normal starting power.
If you do this, stand a good ways away.
I am not an HVAC tech.
Old 06-04-2010, 04:44 PM   #3
Rewards Points: 85
If you can find a tech with an Annie he might break the compressor loose by reversing the rotation.
mikethe ductman is offline   Reply With Quote
Old 06-04-2010, 04:47 PM   #4
An old Tradesmen
Rewards Points: 7,816
So your recommending doing more harm to the compressor to get it to run.
Not to mention frying other parts at the same time.
OP: While you can try a higher powered start kit. You will also be doing more harm to the system if the compressor doesn't start. You'll burn up the windings and cause an acid formation. Which will cost you money to clean up if you op to change out the compressor after that.
Old 06-04-2010, 05:13 PM   #5
trademark for 'Annie'
The description provided to the USPTO for ANNIE is
ELECTRICAL INSTRUMENTS FOR CHECKING AND TESTING REFRIGERATION AND AIR CONDITIONING EQUIPMENT, NAMELY, . . .HERMETIC ANALYZERS, HERMETIC/CAPACITOR ANALYZERS, HERMETIC COMPRESSOR/COMPONENT ANALYZERS, MULTI PHASE HERMETIC ANALYZERS, . . .CAPACITOR ANALYZERS
Sounds like there are several options for diagnosing/fixing this problem.
Do Annies rent for "south of a grand"? If they rent for $500 the OP should rent it if the chance of it fixing the problem for the foreseeable future is greater than 100($500/$3000) = 17%.
Old 06-04-2010, 05:33 PM   #6
Might ask the buyers if they want a compressor in the old system or if they would rather have the cost of the compressor in cash to apply to a new system. Bet they go for the cash towards a new system , you don't have to pay for labor and refrigerant that way. It's a win/win for everybody.
Old 06-04-2010, 05:34 PM   #7
An old Tradesmen
Never rented one. Got one. Hardly ever use it though. They don't cost but a few hundred bucks.
I've freed up more then one compressor, only to have it lock up a few days or weeks later.
Old 06-04-2010, 05:36 PM   #8
An old Tradesmen
Smart buyers will say neither. And want an allowance for a whole new system.
Old 06-04-2010, 06:30 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 148
"I've freed up more then one compressor, only to have it lock up a few days or weeks later."
So VERY true. Hard start kits never last more than a year on a seizing unit. On a new stiff compressor they are useful but when it gets old it just delays the inevitable or expedites it.
Old 06-04-2010, 07:16 PM   #10
Originally Posted by msummers80 View Post
outside AC unit
How old?
Old 06-04-2010, 08:23 PM   #11
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
do you actually have a pending contract on the house? Has the bank approved the sale?
and the biggie: was the AC working when the contract was signed?
Old 06-04-2010, 08:25 PM   #12
nap
You talking to me?
nap's Avatar
It's already a short sale. Highly unlikely the buyers are going to get any consideration for anything.
Old 06-04-2010, 09:00 PM   #13
Licensed Master Plumber
I'll add one more voice to the change the compressor ( or whole unit ) comment. Stuck compressors never, ever work out of it. They just fail shortly after you put a couple hundred dollars into limping them along.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 06-04-2010, 09:08 PM   #14
An old Tradesmen
Buyers aren't worried about it being a short sale. They just worry about what they are getting.
And since there are still many home owners that are either short selling, or selling for just enough to pay off the bank. The buyer still has the ability to say. Ok, I'll look for another place. And probably find one without too much looking or trouble.
Its a buyers market in most areas.
Old 06-04-2010, 10:28 PM   #15
nap
You talking to me?
nap's Avatar
Depending on the answers to the questions, the buyers may simply have to accept it as is. Without the poster answering, there is no way to tell.
and to add: by simply freeing up the compressor, you are building liability for yourself for a claim in the near future should it break down again. The buyers now have a legal right to know the AC is having problems and a failure to disclose that is not a good idea. It would be better to work with it up front.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
Air Compressor Options? gone_fishing Tools 7 11-16-2008 08:42 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Fridge compressor convert to air compressor? jogr Appliances 1 04-24-2008 01:10 PM
