Options For Disguising An Ugly Gas Wall Furnace - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-11-2013, 05:06 PM   #16
Rewards Points: 6,652
Even better, get rid of that archiac unit, and go with a mini-split or high velocity heat pump unit.
You could have a cover built, like they do with radiators, but it would also have to have sheet metal inside to protect the wood, if you make the cover out of wood.
What is the actual output temp of the unit, and what is the temp of the sheet metal covering the unit, when it is running?
You could also do a switch to turn it off when not using, by having it plugged into a switched circuit. I would use a AFCI breaker, or GFCI outlet to protect from any problems though, if I went with that route, just to be on the safe side.
Old 08-11-2013, 05:36 PM   #17
Hvac Pro
yuri's Avatar
Rewards Points: 1,818
If you make any kind of cover it will slow down the airflow patterns thru it and make the house feel worse from lack of circulation plus it could possibly overheat it. Safety and design of the unit come first. Don't want to read about you in the news when you get CO poisoning or there is a fire.
People get CO poisoning from small appliances/units like that one just as easily as bigger furnaces. Gas fireplaces also.
Old 08-11-2013, 05:48 PM   #18
An old Tradesmen
Rewards Points: 6,876
Yep. If the fan moves more air out from the cover, then the cover lets in for heating. It will draw the combusted gasses back in and blow them into the house.
No safe way to cover it, and make it look better.
Old 08-12-2013, 06:36 PM   #19
Rewards Points: 446
The cover comes off the unit. Take it to a automotive body shop and they can paint it any color or even design you want. Other option would be to check with your local high school or technical school to see if they take on projects. Most time they'll do this kind of thing for cost of materials and a small "donation".
By no means cover the unit with anything or try building it in to hide it.
old_squid is offline   Reply With Quote
The Following User Says Thank You to old_squid For This Useful Post:
yuri (08-13-2013)
Old 08-13-2013, 08:08 AM   #20
Hvac Pro
yuri's Avatar
Good Idea, and probably they can sandblast it too. Looks like it is brown and dirty and new paint won't stick to that either.
and to get real fancy maybe they can put some nice racing flames on it.
Old 08-13-2013, 09:53 AM   #21
The entire cover comes off? Or just the front panel? Thanks for the ideas!
dandh is offline   Reply With Quote
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
old wall furnace makes banging noise KarlJay HVAC 22 09-08-2011 01:55 AM
Proper gas line installation for wall furnace rsaritzky Plumbing 2 11-20-2010 12:39 AM
Williams wall furnace whistling noise diyer_mi HVAC 11 10-23-2007 04:05 PM
