Opinions/suggestions On Flush Mounted Thermostats - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-15-2012, 09:08 PM   #31
Missouri Bound's Avatar
You can connect the wires together. If the boiler works, the wiring is connected properly. It's hard to mess up a two wire setup.
Do you want it your way or the right way?
Old 12-15-2012, 09:46 PM   #32
An old Tradesmen
Rewards Points: 6,132
Where are the wires connected on teh boiler. What terminals. probably on terminals marked T T. If so, then if you have the wires connected to RH and W on the stat. Its connected right.
Old 12-15-2012, 10:15 PM   #33
Rewards Points: 225
I'm not entirely sure I'm comfortable doing that. the boiler appears to work with the old thermostat hooked up to it.
when I hooked up the new thermostat and turned on the power to the boiler, it was making that humming noise so I swapped the red and white wires on the thermostat wire with the boiler wires (so red is now wire nutted where the white one was and the white one is now wire nutted where the red one was) and it still made the humming noise. as soon as I swapped the old thermostat in there, the boiler still kicked on when the temperature was raised a degree or two above the current room temperature without any humming.
Here's some photos of inside the boiler - I hope that helps (the brown wire is the new thermostat wire):
while I was taking photos, I also took a photo of the manufacturer badge (Weil McClain):
andrewjs18 is offline   Reply With Quote
Old 12-15-2012, 10:22 PM   #34
Then your wiring is fine
Old 12-15-2012, 10:25 PM   #35
Rewards Points: 225
I sure hope so..I'm getting tired of switching between the two tstats...if only the 'new one' (in reality, I think it's actually older than the old one that has some faulty buttons) worked...
with that said, which one do you recommend for use with 2-wire system that is programmable?
Old 12-15-2012, 10:26 PM   #36
Which hardware store or big box store do you shop at?
Old 12-15-2012, 10:28 PM   #37
Amazon.com: Honeywell RTH221B Basic Programmable Thermostat: Home Improvement
This will work.
Old 12-15-2012, 10:37 PM   #38
Rewards Points: 225
home depot is the closest to me.
Old 12-15-2012, 10:39 PM   #39
The one I posted at Amazon is available at Home Depot...same stat.
Old 12-15-2012, 11:01 PM   #40
Rewards Points: 225
I like this one a little bit better..if it'll work with my system:
http://www.homedepot.com/Heating-Ven...stomer_reviews
Old 12-15-2012, 11:45 PM   #41
whatever works!
Old 12-16-2012, 05:02 AM   #42
An old Tradesmen
It will work with your set up/system.
Old 12-17-2012, 12:56 PM   #43
Rewards Points: 225
thanks for the help guys!
I installed the honeywell I linked to above and all seems well now.
RiteTemp or other Flush Mount Thermostats scootermcrad HVAC 8 11-26-2012 10:54 AM
Flush mounted roof vents Larry Steinberg Roofing/Siding 0 10-01-2011 10:54 AM
Replacement of flush mounted cutting board in kitchen counter top Humby Kitchen & Bath Remodeling 1 07-31-2010 03:45 PM
Flush mount an outdoor load center? wmldwilly Electrical 1 04-29-2009 08:17 PM
Flush mounted fixures Retirement Electrical 1 02-24-2009 01:44 PM
