Opinions/suggestions On Flush Mounted Thermostats - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-14-2012, 03:03 PM   #16
An old Tradesmen
Rewards Points: 8,154
Its not a user friendly thermostat.
Old 12-14-2012, 03:04 PM   #17
Rewards Points: 225
I'm going to give it a shot to see how it is since we were given it for free. if it doesn't work out, I'll go buy a new one.
andrewjs18 is offline   Reply With Quote
Old 12-14-2012, 07:51 PM   #18
Missouri Bound's Avatar
Nothing ventured, nothing gained. Please let us know the results.
Do you want it your way or the right way?
Old 12-14-2012, 08:48 PM   #19
Rewards Points: 225
indeed.
I got the new thermostat wiring ran and hooked up to my old thermostat for now. what a PITA that was! first off, the old wiring was so old that it was tough to tell which was hot and neutral, but it works, so I'm pretty sure that means that it's wired correctly.
second, I got my 1X2 installed behind the hole in the drywall to use as a backstop for the new drywall I'll be installing soon. I bought a 1/4in piece of MDF to glue (using liquid nails) to my 1/2in drywall to make it 3/4in, to be the same depth drywall as what the wall already uses.
I took some photos which I'll post up in a bit.
Old 12-14-2012, 10:11 PM   #20
Rewards Points: 225
here's the 1X2 I screwed to the existing drywall to support the new drywall patch:
and here's a photo of the new wiring going to my old thermostat for now. I'm going to hook up the new thermostat tomorrow. I'll also get photos of the wiring in the boiler tomorrow as well.
Old 12-15-2012, 06:05 AM   #21
My Chronotherm does a good job at getting to the right temp at the right time. THat said, it is a PITA to reprogram every month when the batteries need replacing. The batteries aren't even that used up, but it wants new ones. I now use rechargeables, since I was tired of trying to find uses for the half-used ones that the two Chronotherms I have are so prolific at producing. On that point, I highly recommend Eneloop batteries by Sanyo [or their re-branded equivalent: Pre-Charged by Duracell with the WHITE tops]. They are GREAT products.
Starlight is offline   Reply With Quote
Old 12-15-2012, 01:43 PM   #22
Rewards Points: 225
thanks for the tip. like I mentioned before, if it turns out that this thermostat is a dud, there was no money lost in it from me since we were given it. the one plus its got going for it is that it's not a touch screen so hopefully all of the buttons will work.
Old 12-15-2012, 06:15 PM   #23
Rewards Points: 225
Is there any reason the boiler would make a loud humming noise after I hook up the new thermostat and flipper the power back on to the boiler.
Old 12-15-2012, 06:20 PM   #24
An old Tradesmen
That stat may use triacs. Disconnect on e of the wires and see if the hum stops.
Old 12-15-2012, 07:43 PM   #25
Rewards Points: 225
I disconnected the white wire from the thermostat and the boiler doesn't even kick on now.
Old 12-15-2012, 07:45 PM   #26
Does it run if you short the stat wires? That loud hum may have come from the transformer in your controller...not good if you shorted out the transformer.
Old 12-15-2012, 07:55 PM   #27
Rewards Points: 225
I'm not sure how you'd do that, but when I hook up the old tstat and it kicks the boiler on, it does not hum.
Old 12-15-2012, 07:58 PM   #28
OK..I misunderstood. I thought that after the hum nothing worked anymore...my bad. What features are you looking for in a programmable thermostat? Lowes, Ace Hardware even Walmart have cheap heat only stats that will work for you.
Old 12-15-2012, 08:01 PM   #29
An old Tradesmen
Its the new stat.
Old 12-15-2012, 08:06 PM   #30
Rewards Points: 225
Programmable is really my only need.
Its the new stat.
That's what I thought.
How would I check that the tstat wire is hooked up 100% correctly to the boiler? I think I mentioned earlier in the thread that the old wiring was so old that it was basically falling apart (it's shielding) in my hands so I hooked the new wiring up how I thought it went.
RiteTemp or other Flush Mount Thermostats scootermcrad HVAC 8 11-26-2012 09:54 AM
Flush mounted roof vents Larry Steinberg Roofing/Siding 0 10-01-2011 09:54 AM
Replacement of flush mounted cutting board in kitchen counter top Humby Kitchen & Bath Remodeling 1 07-31-2010 02:45 PM
Flush mount an outdoor load center? wmldwilly Electrical 1 04-29-2009 07:17 PM
Flush mounted fixures Retirement Electrical 1 02-24-2009 12:44 PM
