Opinions/suggestions On Flush Mounted Thermostats - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2012, 03:37 PM   #1
Rewards Points: 225
opinions/suggestions on flush mounted thermostats
Hi,
The previous homeowners of my house installed a ritetemp flush mounted thermostat into the wall in our dinning room. One of the buttons (the temperature down button) on the touch screen went bad so it needs to be replaced sooner rather than later. from reading various reviews online, this seems to be a common problem (parts of the touch screen going bad) with this brand thermostat. I'd like to find a better brand that is vertically flush mounted so I don't have to patch the drywall. does anyone know of any decent flush mounted thermostats on the market?
here's a photo of my thermostat:
andrewjs18 is offline   Reply With Quote
Old 12-12-2012, 05:25 PM   #2
An old Tradesmen
Rewards Points: 6,906
http://www.bonanza.com/listings/Carr...FeiPPAod4m4AYw
http://store.stsi.com/t8024f1007.htm...FcKPPAodEDAAeQ
http://www.prothermostats.com/produc...FZGiPAodQVMAWw
http://www.globalindustrial.com/p/el....campaignId=WP
A couple from a quick google search.
Don't use flush mounts myself.
Old 12-12-2012, 08:02 PM   #3
Missouri Bound's Avatar
Hopefully you can find one from beenthere's links. But I also would not use a flush mounted thermostat. Placement would allow slow reaction to the rooms temperature and may create overheating or overcooling because of that.
Do you want it your way or the right way?
Old 12-13-2012, 12:26 AM   #4
Rewards Points: 225
thanks for the links.
I'm considering just repairing the hole that was cut in the drywall to flush mount the thermostat and installing one that'll just screw into the drywall. for that, what thermostat do you recommend?
Old 12-13-2012, 08:07 AM   #5
[quote=andrewjs18;1072190]thanks for the links.
I'm considering just repairing the hole that was cut in the drywall to flush mount the thermostat and installing one that'll just screw into the drywall. for that, what thermostat do you recommend?[/quote]
Which type of heating system do you have? (gas fired, heat pump, boiler?
A Honeywell thermostat is always a good bet, but many others have come along which also perform very well. What features do you need or want? Outside temperature indiciator, some override features...there are so so many options including wireless and even wi-fi.
Old 12-13-2012, 10:29 AM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 1,842
Honeywell Focus Pro from HDepot is a good DIYer tstat. Flush mount have an opening on the front for the temp sensor but I would still go with the Focus Pro. Your brand is not exactly my favorite if you get my drift.
Old 12-13-2012, 11:53 AM   #7
Rewards Points: 225
I have an old weil mcclain boiler. I believe the thermostat wire it allows for is just a 2-wire. is that a problem? I'm actually going to replace the old thermostat wire with a new one once I install a new thermostat since the old wire is incredibly old.
I'd like something that is programmable.
someone gave my g/f a Trane XT300C thermostat that is brand new because it wouldn't work for them how they wanted it to. is that a decent brand?
Old 12-13-2012, 04:48 PM   #8
5-2 Day Programmable Thermostat RTH230B | HoneywellCentral.com
Here's a simple thermostat you could use. I had a Weil Mclain boiler for over 50 years. Most any 2 wire thermostat will work. Good luck
Old 12-13-2012, 08:58 PM   #9
Rewards Points: 225
thanks for the link. here's some photos I took of my current set up. the problem I think I might have is that the existing drywall is 3/4 in thick. my local home depot only had 1/2 in thick, small drywall squares (maybe a 3X3?). I'll have to build it up to 3/4 in. what do you recommend on doing that? gluing some fiberboard to the back or the drywall?
Old 12-13-2012, 09:04 PM   #10
Anything to build up the drywall would be fine. I doubt it's 3/4". You could always find a nice unfinished plaque in a craft store and mount the new stat in the iddle of it and screw the plaque over the hole. You could paint or stain it.
Old 12-13-2012, 09:52 PM   #11
Rewards Points: 236
with that finish on that wall, that is what i would do.
Fix'n it is offline   Reply With Quote
Old 12-13-2012, 10:47 PM   #12
Rewards Points: 225
unless my tape measure is lying, it's 3/4". I'm just going to find something at home depot tomorrow and some glue to build up the 1/2 in drywall I have.
so, before I attempt to install this thermostat that my g/f got from a friend, I'd like to know if it'll work out. will this work out ok?
http://dl.owneriq.net/d/d1272c37-64d...7294bdf6e5.pdf
the previous homeowners left some of the paint they used to paint the dinning room walls, so I'm good to go there.
Old 12-14-2012, 03:52 AM   #13
An old Tradesmen
Is that 300c battery operated.
Its a relabeled Honeywell chronotherm. Most people ended up hating them.
Old 12-14-2012, 04:13 AM   #14
seal the hole and use a thermostat backing plate http://www.southsidecontrol.com/acat...651A_3169.html
mrairflow is offline   Reply With Quote
Old 12-14-2012, 11:32 AM   #15
Rewards Points: 225
I'm actually not sure if its battery operated or not.
why do most people end up hating the chronotherm?
RiteTemp or other Flush Mount Thermostats scootermcrad HVAC 8 11-26-2012 09:54 AM
Flush mounted roof vents Larry Steinberg Roofing/Siding 0 10-01-2011 09:54 AM
Replacement of flush mounted cutting board in kitchen counter top Humby Kitchen & Bath Remodeling 1 07-31-2010 02:45 PM
Flush mount an outdoor load center? wmldwilly Electrical 1 04-29-2009 07:17 PM
Flush mounted fixures Retirement Electrical 1 02-24-2009 12:44 PM
