Open Studs And Insulation In Duct Behind Honeywell Humidfier Filter - HVAC - DIY Chatroom Home Improvement Forum
Old 10-15-2012, 05:49 PM   #1
Exclamation
Open studs and insulation in duct behind honeywell humidfier filter
When i removed my filter for my Honeywell whole house furnace humidifier i noticed a square cut inside the top of the duct where I could see ceiling joists and insulation...Is this normal? I thought all ducts should be sealed (air tight)
Should i seal it?
[ATTACH][ATTACH]Open studs and insulation in duct behind honeywell humidfier filter-2011-10-04-20.09.05.jpg[/ATTACH][/ATTACH]
Open studs and insulation in duct behind honeywell humidfier filter-2011-10-04-20.08.19.jpg   Open studs and insulation in duct behind honeywell humidfier filter-2011-10-04-20.08.26.jpg
Ronz40 is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 10:09 PM
insulation between drywall and studs CNM Design Drywall & Plaster 0 06-04-2011 05:05 PM
Insulation with doubled studs HooKooDooKu Building & Construction 2 04-29-2010 09:27 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
