Open High Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 11:57 PM   #1
open high switch
what does it mean when you have an open high switch
malcolm x is offline   Reply With Quote
Old 03-05-2011, 12:07 AM   #2
i could really use the help
Old 03-05-2011, 01:32 AM   #3
JJboy's Avatar
Are you talking about high pressure switch?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 03-05-2011, 12:08 PM   #4
An old Tradesmen
Rewards Points: 6,570
Don't expect an answer in just 10 minutes.
Have you cleaned or replaced your air filter recently.
Old 03-05-2011, 12:16 PM   #5
Experienced
Jackofall1's Avatar
If I were to literally interpret that statement "Open High Switch" I would have to go back to my college days, and roll a couple before I openned that switch.
OR
You could help us interpret that statement by providing some additional information.
Mark
Old 03-05-2011, 12:36 PM   #6
how
Rewards Points: 1,102
Where are you seeing the term open high switch? What kind of heating system do you have. Age, brand, size, & style. Are you reading that off a diagnostic thermostat, furnace diagnostic display, flashing led display interpretation????
It's an unusual term for either pressure or limit switches.
how is online now   Reply With Quote
pressure switch is open slowplayed28 HVAC 2 10-31-2010 09:43 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Could a failed condensor fan raise pressure/trip high pressure limit switch? (Rheem) hennyh HVAC 6 07-30-2009 03:04 PM
high limit switch tarheelhvac HVAC 4 06-15-2009 07:52 PM
Comfortmaker RPJII - 4 flashes - open high limit switch nisad HVAC 7 12-08-2006 12:33 PM
