Open Contactor On Lennox A/C Condenser 10ACB30 - HVAC - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 07:34 AM   #1
Rewards Points: 16
Open Contactor on Lennox A/C Condenser 10ACB30
I recently replaced my blower control circuit board on my Lennox G26 Series Furnace, and after replacing the circuit board, the contactor remains open. The contactor's terminals display the 24V. I can manually close the contactor, and the compressor runs.
Could it be the circuit board?
tonygharris is offline   Reply With Quote
Old 08-25-2011, 02:04 PM   #2
An old Tradesmen
Rewards Points: 6,836
Where do you have the low voltage wires connected on the board that go to the outdoor unit.
The Following User Says Thank You to beenthere For This Useful Post:
tonygharris (08-25-2011)
Old 08-25-2011, 05:36 PM   #3
REP
If you have 120 volts to a lamp and the lamp doesn't come on when you flick the switch ,does that mean that wall socket is bad?
HVAC can be complicated but if you have voltage to anything and it don't work,what does that tell you.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
Old 08-25-2011, 06:33 PM   #4
biggles's Avatar
if you have 24V on the condenser contactor connected or loose....ring the compressor coil out with the ohms setting on your meter...shut the condenser sisconnect off the 24Vs comes from the air handler/furnace not the condenser so you will only be working with 24Vs control ...and no being concerned with short cycling the compressor
The Following User Says Thank You to biggles For This Useful Post:
Old 08-25-2011, 08:40 PM   #5
Rewards Points: 16
Thanks for your response.
After further testing, I do not have 24V at the contactor. I have checked the thermostat, transformer and contactor, and they're OK. However, I'm not getting 24V on the circuit board 's thermostat cooling (Y) and fan (G) terminals that feed to the contactor. I visually examined the back of the circuit board, and there was no discoloration or appearance of an overload. Any other suggested tests to determine the open contactor problem.
Old 08-25-2011, 09:08 PM   #6
Should be Y and C going to the contactor. No 24 volts between Y and C at the furnace terminal strip is a bad thermostat.
Old 08-25-2011, 09:28 PM   #7
I'm Your Huckleberry
Rewards Points: 2,270
24 volts potential across the contractors, from each side?
Low voltage is not making.
Doc Holliday is offline   Reply With Quote
Old 08-26-2011, 06:57 AM   #8
Rewards Points: 16
Thanks, I will perform these checks and let you know if it is a bad thermostat.
Old 08-26-2011, 06:59 AM   #9
Rewards Points: 16
Old 08-26-2011, 03:33 PM   #10
An old Tradesmen
G isn't suppose to be connected to the A/C contactor. Y and C are to be connected to teh A/C contactor.
Old 08-28-2011, 12:02 PM   #11
Rewards Points: 16
Lennox
Once the Y was conncected to the C on the circuit board, everthing is working fine.
Thanks for your expertise and assistance.
Old 08-28-2011, 12:05 PM   #12
Rewards Points: 16
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 07:05 AM
Lennox Condenser Hums brokenhammer HVAC 2 05-23-2010 11:10 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
Lennox HS29-311-3P Air Conditioner Not Working olgranddad HVAC 13 06-23-2009 11:39 AM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 06:03 PM
