Open Chimney - HVAC - DIY Chatroom Home Improvement Forum
Old 03-01-2011, 04:38 PM   #1
Open chimney
So I was looking for a chase from the basement to the attic when i removed some ceiling tiles in the kitchen around where the wall is framed out around the chimney. I was astounded to find a huge opening in my chimney right into the kitchen ceiling! The chimney has no liner. I don't know how this hasn't caused problems before but I've been here 15 yrs. Can I just plug this hole with mesh and some cement or is there a better solution?
Jj375 is offline   Reply With Quote
Old 03-01-2011, 05:41 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,844
That should work. Probably had a wood burning stove connected there many moons ago.
Old 03-04-2011, 03:49 PM   #3
open chimney
It would be a good idea to have a new lining system installed!! the chimney works as a negative pressure system meaning it will suck air from inside the house unless there is a blockage , or a wind related down draft them it will spill carbon monoxide into your home. Who knows what the rest of the flue looks like don't take a chance, have it re-lined!!
chmnyman is offline   Reply With Quote
Old 03-04-2011, 06:10 PM   #4
I just installed a new purefire boiler with direct vent. So the chimney is out of use. I was just baffled that I had no problems from it. I've lived here 15 yrs and have co detecters in the house that never registered anything.
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 06:16 AM
Chimney repair advice needed cbrc5eric Building & Construction 2 04-04-2010 06:32 AM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 07:00 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
