OOPs Hole In Fireplace Duct. - HVAC - DIY Chatroom Home Improvement Forum
Old 12-18-2008, 12:00 AM   #1
Question
OOPs hole in fireplace duct.
I was putting in a vents in our new bathroom and accidentally started drilling into the fireplace vent. The hole is only about 1/2 in diameter before I realized what had happened. There isn't gas roaming around in there, it is simply a vent to spread the heat around from the gas fireplace. Will some insulating foam sealant seal that up well enough or do I need to do something else. If someone knows please let me know.
TJHK22 is offline   Reply With Quote
Old 12-18-2008, 06:01 AM   #2
Whatamess
I would get some Hi Temp silicone at the local auto supply and seal the hole.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 12-18-2008, 08:13 AM   #3
An old Tradesmen
Rewards Points: 6,116
Get a " knockout plug, and silicone it in.
Old 12-24-2008, 06:00 AM   #4
Tried to search google and got more information..
ductworksystem is offline   Reply With Quote
Old 12-24-2008, 06:24 AM   #5
the Musigician
DangerMouse's Avatar
perhaps a self tapping, 1/2" bolt?
if no fumes are there nor super high temps, it should be fine, imho
if necessary, gasket it with fire block caulk or refractory cement?
DM
Old 12-26-2008, 06:46 AM   #6
the Musigician
Originally Posted by handyman4life View Post
After we determined that the hole was too small for the fireplace, ... The fireplace sucks in outside air down one duct, burns that outside air, ...
huh???
DM
Old 12-26-2008, 08:11 AM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 1,130
One pipe is exhaust and the other combustion air. Seal it up good with RTV silicone and keep checking it once a year.
Hole in my dryer duct... QuattroStylez Building & Construction 6 11-30-2008 05:11 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
