Only 4 Of 5 Burners Light On My Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-07-2012, 01:24 PM   #1
Only 4 of 5 burners light on my furnace
I have a 12 year old Comfortmaker gas furnace.
It operated fine all last winter.
When I went to fire it up the first time today, only 4 of the 5 burners light off (burners 2 thru 5 when counting from where the gas enters the manifold).
The ignitor is in front of burner 5, the ignition sensor is in front of burner 1.
Because burner 1 never lights, there is no ignition feedback and after 15 or 20 seconds the gas valve closes. It will retry about 4 times before going into a soft lockout because of the failed ignition.
I don't see any obvious blocakges in the burner nozzles.
Any thoughts on how to proceed?
Chris66204 is offline   Reply With Quote
Old 10-07-2012, 01:48 PM   #2
JJboy's Avatar
Check the gas pressure and clean the burners.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-07-2012, 01:51 PM   #3
biggles's Avatar
you said burner nozzle but what about the manifld fitting that feed that #1 buners track..pop out the burner spider or bug is blocking the gas into it...box end wrench soft tap loosen it,and finger tight back in with a tweek from the box wrench to tighten it...mine as well check them all ...wire brush the ignition track along the burners...except for 1 and 5 all others are the same when you pull them out
The Following User Says Thank You to biggles For This Useful Post:
oh'mike (10-07-2012)
Old 10-07-2012, 01:52 PM   #4
how
Rewards Points: 1,102
Usually a bit of debris in the crossover between the burners that are burning and the one that is not.
how is offline   Reply With Quote
Old 10-07-2012, 03:05 PM   #5
Update -
I pulled the burner manifold fitting and verified it was clean.
I also adjusted the pressure and no joy.
I'm thinking there is something to How's response - I can see the flame on the crossover between all the other burners but it is non-existent between burner 2 and burner 1.
I'm going to try and clean that up, but if you have any specific things to look for there, please let me know.
Old 10-07-2012, 03:26 PM   #6
how
Pull the burner that isn't lighting and the one beside it that is. Look for a thin slot on eitherside of the burners that allows the burner flame to travel from one to the next.. A metal strip from a tin can is thin enough to use as a tool to clear out any debris. If you are unable to remove the burners, you can bend your metal tool into a "U" and still may be able to clear them.
Old 10-07-2012, 04:48 PM   #7
AKA HVACTECHFW
Rewards Points: 1,208
pull and clean ALL the burners
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
ben's plumbing (10-07-2012)
Old 10-07-2012, 06:27 PM   #8
An old Tradesmen
Rewards Points: 6,498
So what pressure do you now have it set to? You did use a manometer to adjust it right.
Old 10-07-2012, 06:34 PM   #9
Rewards Points: 582
yes pull entire burnner assy and clean them all....also as beenthere said what did you set manifold pressure to and with what...ben sr
Old 10-07-2012, 07:01 PM   #10
Pulled the burner assembly and cleaned the crossover assemblies. Started up just fine after that. Thanks for all the help.
Tags
burners , furnace , ignition
90-year-old Furnace Burners won't light asenada HVAC 15 10-24-2012 02:51 PM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
Furnace burners will shut off after 10 mins Liberator HVAC 10 01-20-2012 11:23 AM
gas furnace, burners wont stay on mikerva HVAC 3 01-19-2012 05:01 PM
Furnace won't light Babybird HVAC 2 03-30-2007 10:48 AM
