Only 1 Thermostat Triggers Boiler... - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-15-2010, 06:35 PM   #16
An old Tradesmen
Rewards Points: 7,372
With zone 4 turned down so it isn't running the circ.
Turn up the stat of one of the zones that doesn't run the circ. Go to that zone valve. Tie the 2 red wires together. If the circ runs then. Its the micro switch.
If the circ doesn't run. Then it is something else.
Old 10-15-2010, 10:57 PM   #17
Will try that in the am, off to work again.
Thanks, Bill
Wmoore is offline   Reply With Quote
Old 10-17-2010, 02:55 PM   #18
Joining the reds on zone 3 without zone 4 calling for heat worked. Did not try 2 and 1 so I will assume all 3 need new end switches. I am thinking they can't cost much. Still wondering about the dim light on the control board for zone 4 when he needs heat, but if all works I may forget about it.
Thanks, Bill
Boiler still runs even when thermostat is off jamegail1 HVAC 25 10-05-2010 02:21 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Wiring new thermostat to the boiler keano016 HVAC 0 11-13-2009 09:12 AM
Boiler size Bonnie Youngs HVAC 29 07-10-2009 07:58 PM
