One Too Hot Room, Help.. - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2008, 06:27 PM   #1
One too hot room, help..
I have steam heat, one pipe system. I have a room that is toooo hot, since it's a one pipe system I can't close the valve partially, it has to be either fully open or fully closed. I know there are steam vents out there that are adjustable, does anyone know or have tried any of those adjustable vents and would recommend any? Thanks, I figure if I can use an adjustable vent and minimize the heat in that room, that would help. The radiator is not that big, but neither is the room size, lol. Any recommendations are greatly appreciated. Thanks
helpless handyman is offline   Reply With Quote
Old 02-01-2008, 06:47 PM   #2
** I was thinking of the Hoffman 1A which is adjustable, but looking for advice..
Old 02-01-2008, 08:34 PM   #3
Learning by Doing
Leah Frances's Avatar
Link to detailed explanation
I posted a detailed description of how I did this very thing. Radiator Tune Up goes WELL! How I did it.
I used Honeywell valve bodies and thermostatic valves with Vari-valve adjustable vents. Got a good deal on the valves on ebay.
I am very happy with them.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-02-2008, 07:23 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
http://www.pexsupply.com/product_dtl...offman&cID=301
They work fine.
chrisn is online now   Reply With Quote
Old 02-02-2008, 07:28 AM   #5
chrisn's Avatar
Rewards Points: 394
I posted a detailed description of how I did this very thing. http://www.diychatroom.com/showthread.php?t=16462
This is a one pipe system?
Old 02-02-2008, 05:38 PM   #6
Learning by Doing
If that's a question for me, the answer is yes.
Old 02-02-2008, 08:35 PM   #7
Yes, it's a one pipe system.
Old 02-03-2008, 09:04 AM   #8
chrisn's Avatar
Rewards Points: 394
The question was for Lea hand I was just wondering where you are installing all of this hardware/ On mine there is only a place for the air valve vents to be replaced,am I missing somrthing?
Room Air Purifier - which is best? nhart Appliances 17 07-29-2014 09:00 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 02:51 PM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 05:34 PM
Room to Room Vent cjpilot HVAC 5 12-02-2007 08:53 PM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 03:08 PM
