one themostat for a/c and evap cooler?
I have both and am looking to get a programmable thermostat. I was hoping it was possible to get one that could control both the regular a/c and my mastercool evaporative cooler. Is this possible? Any recommendations?
Thanks for the help! |
Assuming you want to first turn on the evap cooler, then if the temp continues to rise, bring on the A/C, you'd need a t-stat that has 2 cooling stages, and also two 24 volt relays.
One relay would control the evap cooler, the other would lock out the evap cooler when the A/C kicks in. If you'd like a different control scheme, please describe it, and we'll help you through it. Rob |
Micromind, thanks for the reply.
I guess it would be nice to have it automatically switch-over from the evap to the a/c once the temp hits a certain point, but that isn't necessarily a feature that I absolutely need. I would be happy with a setup that would allow me to get rid of the ugly mastercool thermostat and get one programmable thermostat that allows me to choose if I want to cool with the evap or a/c. Switching it manually would be ok with me. Can you suggest a specific model that is capable of doing this? I have been looking at these thermostats: http://www.prothermostats.com/produc...9&category=260 http://www.prothermostats.com/produc...1&category=260 http://www.prothermostats.com/produc...6&category=260 Would any of those 3 work? Sorry, I'm an idiot when it comes to electrical things, so I'm trying to avoid buying something that isn't going to work for me. Thanks a bunch for the help!!! |
Any of these t-stats will work. If you want to choose which system turns on, you'll need to install a switch to toggle between the two systems. I don't think any t-stats have that capability.
Assuming your A/C unit is single stage (most of them are), you'd need 1 relay with a 24 volt AC coil, and contacts that are rated to handle the evap cooler motor. You'd also need 1 single pole double throw switch, it'll only need to handle 24 volts AC, and very small current. Make sure you have enough control wires from the A/C unit to the t-stat. If it's A/C only, you'll need 4, if it's A/C + 1 stage of heat, you'll need 5, and with 2 stages of heat, you'll need 6. If you're replacing a mechanical t-stat, there might be enough wires, one or more will be spare. If you want it to start with the evap cooler, then bring on the A/C on further temperature rise, you'll need 2 relays, no switch, and it'd help alot if the t-stats deadband were adjustable. |
Would this make it too humid? BTW, this is the a/c + gas heat unit I have: http://www.colemanac.com/homeowners/...tems/index.asp Sounds like I might be hiring a pro to do this installation... |
I don't think it would be a good idea to have both units on at the same time, the reason I suggested 2 relays is one to start the evap cooler when the t-stat calls for 1st stage cooling, and the other one to stop the evap cooler and start the A/C when the t-stat calls for 2nd stage cooling.
If both units ran at the same time, I'd bet the evaporator coil on the A/C would ice up pretty quickly. Rob |
Rob,
I re-read your first reply and that is exactly what I want to do. I must have missed the part about "locking out the evap cooler when the A/C kicks in" when I read it the first time. :wallbash: But I am a little confused by something you said. "If you want to choose which system turns on, you'll need to install a switch to toggle between the two systems. I don't think any t-stats have that capability." Do I need to worry about this, or will a thermostat with 2 cooling stages and 2 24V relays do the trick? Just trying to understand what flexibility installing the toggle switch buys me. I really appreciate you taking the time to explain all of this! This forum is great! Thanks, Matt |
If you'd like the system to be completely automatic, a t-stat with 2 cooling stages and two 24 volt relays will do it (no toggle switch). If you can find a t-stat with adjustable deadbands, (that's the number of degrees of temperature change from cooling start to cooling stop), it'd be better. You'll likely need to play around with the deadbands a bit.
The toggle switch would be needed only if you want to manually choose which system came on when the t-stat called for cooling. A single stage t-stat would be ok here. Rob |
Ok, looks like I'll be getting a thermostat with two cooling stages, two 24 volt relays, and adjustable deadbands.
You have been so helpful! Thank you very much! Matt |
| All times are GMT -4. The time now is 11:52 PM. |
