This One Is Really Cool. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-13-2013, 10:46 AM   #1
this one is really cool.
This bad boy is the most rugged temp tester I have ever owned!
I used it in conjunction wit the Insight. Dead on. The only draw back is K couple length. Not long enough to reach the supply and RA ducts.
Boss called UEI and they sent a ten foot K-couple extension free of charge.
It has four measuring ports and does differential measurement.
Does not have a magnet on back. But that easily remedied.
hvac5646 is offline   Reply With Quote
The Following User Says Thank You to hvac5646 For This Useful Post:
ben's plumbing (10-13-2013)
Old 10-13-2013, 10:48 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,396
I have a UEI manometer and it goes from -40F to a 70F house regularly and is tough as nails. Good units. Mine has the magnet.
The Following User Says Thank You to yuri For This Useful Post:
Old 10-13-2013, 11:09 AM   #3
Yeah, I got that one too! Along with a Testo 510 and a Fieldpiece manometer.
I use all three on check ups. Individually they each definite purposed. Such as the UEI a three place decimal reading te very fine measurement.
The FP has no + or - polarity. Just hhok up the hoses and read TSP. P1 gives the static of what ever side of the system its hooked up to. Same wit P2.
Testo 510 has different settings you can use a pitot tupb wit for super accurate traverse readings.
Old 10-13-2013, 12:00 PM   #4
Hvac Pro
yuri's Avatar
Only problem is when it is -40F you got to stick it under your armpit for several minutes 2 warm up the batteries or it won't light up and that is COLD.
Old 10-13-2013, 12:11 PM   #5
Does not get that cold here. but on the days it is I'll use a hair drier on it.
Old 10-13-2013, 12:37 PM   #6
Hvac Pro
yuri's Avatar
So cold here it will freeze the snot in yer nose.
I know, too much information.
Very Cool Air Coming out of Air Blower Unit? ltanner9416 HVAC 11 08-06-2012 10:40 PM
Pool deck cool deck chalking hammmer13 Building & Construction 5 12-01-2011 09:32 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
Water from cold water faucet goes from cool to hot to cool tima2381 Plumbing 6 05-22-2007 09:02 AM
new 3 ton hvac Payne units. No cool air comes out when fan, compressor,thermostat run runbikeengr HVAC 10 04-10-2007 06:59 PM
