One Pipe Steam Heat ? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-05-2010, 06:47 AM   #1
Doing a small "L" shape extension on a home and they have an existing steam system. The 3 windows we're putting in are 10' long.
So my question is, how good are steam baseboards or are they better off with standard steam radiators and getting a pitch on the far one is going to be almost impossible without some serious demo and repairing.
Thanks in advance.
II Weeks is offline   Reply With Quote
Old 03-05-2010, 07:06 AM   #2
An old Tradesmen
Rewards Points: 6,560
If they have cast iron rads in the rest of the house. Then the addition won't heat as well will baseboard.
Did you check to see if the boiler can handle the additional load.
Old 03-05-2010, 03:27 PM   #3
Licensed Master Plumber
Be better and easier to run a wet leg hydronic loop off the steam boiler.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 03-05-2010, 08:16 PM   #4
An old Tradesmen
If done right.
Old 03-05-2010, 08:47 PM   #5
I'll second that motion
Old 03-06-2010, 07:33 AM   #6
They do have cast iron rads now that we'll be removing where the extension is and basically coupling out to where the new ones will be needed and increasing their size by a little. Really is a small extension, just a lot more windows with hi R value and 2X6 walls for R 19.
Not even going to touch that one. Never heard of it but I'll look into it and let the home owner know his options and for that one, he'll need a good plumber.
Thanks for the replies. Really appreciated.
Old 03-06-2010, 07:39 AM   #7
heres something from B &G
How to Run a Hot Water Zone Off a Steam Boiler
Here's a simple way to add a hot water zone to a steam-heated building without using a heat exchanger. Your new zone can serve an indirect domestic water heater, or a baseboard zone, but that zone must be not more than 30 feet above the boiler water line. At higher altitudes, it will have to be even closer to the boiler, because of the drop in atmospheric pressure.All you'll need will be an all-bronze Bell & Gossett Series l00 circulator, two BSA-3/4 Flo Control valves, an angle thermometer, three full-port 3/4" ball valves, a switching relay, an Aquastat and a few feet of 3/4" copper tubing.
Here's how you do it. First, you have to remember that this is an open system. The water above the boiler water line can easily be hotter than 212 degrees when the boiler is steaming. The only thing that keeps the water in a liquid state is the pump's pressure. The trouble is, when the pump is shut off, its pressure vanishes. When that happens, the hot water in the radiator can flash to steam, creating a racket in the radiator and driving the water back down to the boiler.
But that won't be a problem for you because one of our ITT Bell &Gossett Representatives came up with a simple trick years ago to solve this problem. They used a bypass line (through the bottom of the two SA-3/4" Flo-Control valves) to blend the cool return water from the zone with the hot supply water from the boiler. The Flo-Control valves also do a great job of preventing gravity circulation into the zone once the thermostat is satisfied.
Pipe it as we've sketched it, and then fill your new zone with a hose attached to Boiler Drain #l. Purge the zone and the bypass piping back to Boiler Drain #2. Make sure you have Ball Valves "A" and "B" closed, but leave Ball Valve "C" open. Now, don't use automatic air vents in your new zone because they can let air in as well as out. If air gets into the top of the zone, the water will fall back into the boiler, but if you leave out the vents, the water will stay up in the piping. You know why? Because of atmospheric pressure. It's the same force that keeps water in a straw when you hold your finger over the end and lift it from a glass. We think simple ways are the best, don't you?
Next, steam the boiler and start your all-bronze Series l00. Use your two ball valves ("A" and "C") to blend the water between the boiler and the bypass until you get a 180 degree reading on your thermometer. (Valve "B" is for service only and normally stays open.) Then, take the handles off the ball valves and you're set; you'll never have to touch the system again.
You'll control your new zone by cycling the Series 100 and the burner with a room thermostat (through the switching relay and the Aquastat). If you're not making steam for the rest of the house or building, the burner and the circulator will come on at the same time, and the boiler will run up to the aquastat's high limit. If the water is hotter than 180 degrees (as it would be if the steaming cycle had just ended), only the circulator will run to satisfy the hot water zone. Beautifully simple, isn't it.
We recommend you use an all-bronze Series 100 for this service because condensate is usually very acidic and tough on ordinary pumps. The all bronze Series 100 is a workhorse that will last for many years, even on this rough-and-tumble duty. Another plus is that the Series 100 has a much wider opening through its impeller and waterway than, say, our smaller Red Fox circulator. Because of its wide waterway, a Series 100 is much less likely to clog with steam-system sediment than other pumps. That translates to happy customers, and no) callbacks..
Old 03-06-2010, 07:49 AM   #8
An old Tradesmen
If you check the heat loss of the existing construction. And then the new addition. You will probably find that the new addition even with those windows has less heat loss then the existing structure does.
Key phrase in that diagram. Is "pipe it as drawn"!
Old 03-06-2010, 08:54 AM   #9
I agree with that and thats why we're not too worried about the boiler being capable.
A lot of choices in modern radiators out there as well. All very interesting stuff but I hope they decide to get a plumber to do the wet leg. Baseboards are so much easier and I'll be long gone with my work.
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
steam heat radiator Daniel52 Plumbing 1 09-09-2009 10:56 AM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
Steam Heat - Radiator Enclosure Leah Frances HVAC 1 01-27-2008 02:49 PM
Leaky Steam Heat Pipe NJE HVAC 6 01-30-2007 09:26 PM
