Old 10-10-2007, 05:45 PM   #1
Default One furnace question and one thermostat question
1. Hello a question about furnace. The furnace in my house has two gas valves, the one on the left always light right away; on the other hand, the one on the right doesn't! It takes a second or two longer than the left one after gas is released. And even worse, sometimes it doesn't light at all, maybe after a few tries, I had to recycle the furnace occasionally because of this.
My question is, do I have a bad/dirty gas valve? Can it be cleaned or does it need replacing?
2. Also another question about my thermostat, it's a NOVA 5+1+1 (crap I know), the temp reading is always a few degrees higher than the actual temp, I guess there's no way to adjust this?
Also our second floor is about 5 degrees warmer than the main floor, I guess this is because warmer air goes up. But is there a way to change this? maybe a huge fan somewhere along the stairs?
I apologize for asking silly questions again but for the newbie I am
Thank you.
lh0628 is offline   Reply With Quote
Old 10-11-2007, 11:02 AM   #2
1. Looks like some cleaning is in order.
2. I am not familiar with your 'stat model. My units (RiteTemp touchscreen programmable) have a temp reading adjustment feature. But you could simply set target temp a few degrees higher to compensate.
3. You could fiddle with 2nd floor registers and partially close them so that you have less warm air going to 2nd floor.
scorrpio is offline   Reply With Quote
Old 10-11-2007, 11:49 PM   #3
retired
Does the furnace shut down automatically when the second burner doesn't light? Is that why you have to recycle it?
If that's the case you need to get a furnace man in there fast. Any time you have an open gas valve without ignition in the prescribed time you are risking an explosion. That furnace is telling you something is not right. Don't mess around trying to do a fix on the cheap.
You might have something like a burned out combustion chamber that causes the flame to not burn correctly and that's why the second burner doesn't light. Do you ever detect the odor of gas in the house?
dmaceld is offline   Reply With Quote
Old 10-11-2007, 11:57 PM   #4
Thank you for your replies!
Scorrpio, I'll go with the simple solution and just adjust the temp a few degrees higher, but where is this 2nd floor register thing? Is it on the furnace itself or is there an actual sensor somewhere in the air vent?
dmaceld, the furnace tries to light 3 times, and if all 3 failed, the blower fan will go off, everything goes off, but the indicator light would blink, normally it's solid. I don't think I'll have an explosion though, because only a small amount of gas is released each of the 3 times, and if they all fail, the furnace won't release any more gas.
How do I go about cleaning my furnace? Is this something I can do myself or does it require special tools for cleaning air vents etc, which I imagine special tools will be required.
Thank you again for helping!
Old 10-12-2007, 12:17 AM   #5
retired
The short answer is, you don't. Cleaning may or may not be the answer. The problem is most likely inside the furnace, as in where the fire is. It isn't so much special tools required to get in there, but knowing how to get in there and what to look for. Not a DIY job for the average person. Once again, I emphasize, the furnace shutting itself down is telling you it has a serious problem, and needs some serious looking at. To put it bluntly, judging from the nature of your questions you are not the one to do it.
More On This Topic
Hi, I'm Nipa Banerjee from Arts Space India I'm talking on behalf of Expert Village. This is the furnace and this is the door of the furnace, see these are ceramic tiles, this is fiber and these there is 2 coils inside the furnace. After finishing up the... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip, I will be talking about work area safety. First, off you want to make sure to keep your work area clean and well lit. Any type of clutter or dark areas invite accidents. You want to make... Read More »
Hi I’m Anna from annawillowglassdesign.30art.com and I am going to show you how to make an interesting shaped Christmas ornament using an optic mold. Now I am going to go over here and gather out of the furnace onto the blow pipe. I am actually... Read More »
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
