One Cold, One Not, Same Plenum, No Leak - HVAC - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 01:57 PM   #1
One cold, one not, same plenum, no leak
2 duct branches from the same plenum give out different air tempurature. One gives out cold air, one is not.
Both airflow is equally sufficient (so there is no leak or blockage, or else it would give discrepancy in airflow). To confirmed, I have checked the trunk itself and found no air leak.
I am baffled, perplexed and beat.
Mike
minh.nguyen2 is offline   Reply With Quote
Old 08-08-2011, 02:21 PM   #2
Rewards Points: 6,652
Has it always been doing this, has anyone been doing any work on this house, or playing around with the dampers for the duct work?
The Following User Says Thank You to gregzoll For This Useful Post:
minh.nguyen2 (08-09-2011)
Old 08-08-2011, 02:29 PM   #3
Problem just this summer
No dampers are found along the trunks.
Seems the system only has registers on room ceiling
I just dont get it! if something worng with the unit, then all trunks from the same plenum would be equally effected
Old 08-08-2011, 09:20 PM   #4
What kind of ducting do you have? And how far apart are the vents.
Generally speaking, the vent closest to the unit will be the coldest. The furthest duct is the warmest. The duct system can pick up heat from the attic. Make sure everything is well insulated.
Master of Cold is offline   Reply With Quote
The Following User Says Thank You to Master of Cold For This Useful Post:
Old 08-09-2011, 04:59 AM   #5
An old Tradesmen
Rewards Points: 7,730
If it just started this year. Check duct insulation first. If its ok. Then good chance the evap coil is dirty, and causing air stratification in the plenum.
The Following User Says Thank You to beenthere For This Useful Post:
Old 08-09-2011, 10:15 AM   #6
thanks everyone for your insight. I'm putting pieces of info together. How do I go about to clean a dirty evap coil ?
Old 08-09-2011, 10:29 AM   #7
can i do this myself or need to call a technician?
the unit is 20 years old. IS there a possibility for a new replacement? which will be costly
Old 08-09-2011, 10:33 AM   #8
Important thing to add:
the cool branch is gradually becoming warmer. I suspect its a matter of time before both branch stop giving cool air. Another word, the pproblem is spreading to the entire system.
Old 08-09-2011, 10:35 AM   #9
JJboy's Avatar
If you have access to the bottom of the a-coil you can do it. The best way to clean is removing the a-coil.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 07:00 PM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 01:44 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 06:30 AM
Old Return air plenum for new furnace? Chemist1961 HVAC 1 12-25-2008 10:20 AM
