One A/C Vent Leaking In House. - HVAC - DIY Chatroom Home Improvement Forum
Old 09-11-2012, 12:39 PM   #1
One A/C vent leaking in house.
One A/C vent leaks in a bedroom. After a leak in the ceiling of the same bedroom and the A/C not producing cool air in the house, I had the runoff pipes cleaned, freon checked and coil cleaned. A/C worked well for about 5 days and then vent leaked. Any ideas why my vent is now leaking?
Mark86 is offline   Reply With Quote
Old 09-11-2012, 03:38 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
What do you mean by vent? The supply grill/register where the air comes from? That has condensation (water) leaking from it? Is that what you mean?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 09-11-2012, 06:36 PM   #3
Yes. The air supply vent with grill and lever to open and close.
Old 09-11-2012, 07:17 PM   #4
Easy peasy fix, my friend! The dry cool air coming from the air conditioning vent is mixing with the warm humid air surrounding the vent. What this does is ring the moisture out of the warmer humid air, like wringing out a wet dish cloth or towel. I've come across this a few dozen times, can be one of two things: the grill itself from up top in the attic needs to be sealed where it penetrates the sheetrock and then you need to toss and pack down some attic insulation around it.
You can use mastik for this job, apply with a cheap paint brush.
or the duct itself has come loose from the register or has a hole in it at the grill. You may be able to tell by removing the grill from the ceiling but this is what it should resemble up top:
Liner taped to metal register. Note the sheetrock around the grill, not insulated.
And then the insulation from the duct pulled over it all and sealed. Now note the attic insulation all around the grill.
You can use the aforementioned mastick instead of tape to seal all around the grill. Gray or white, doesn't matter.
Your a/c system is working just fine, this is more of a construction/install issue.
Thanks.
Old 09-12-2012, 01:34 PM   #5
Great! I'll give those a try Thank you.
dryer/bathroom vent terminations and window clearances itsnotrequired HVAC 14 04-29-2012 08:55 PM
Dryer vent leaking imhotep Roofing/Siding 7 12-28-2011 04:54 PM
Water/Ice on fascia leaking into sofit and house da_man Roofing/Siding 1 02-07-2011 04:22 PM
bathroom vent leaking listo HVAC 3 01-24-2009 07:15 PM
leaking vent stack joint xrayman Plumbing 10 03-04-2008 04:23 PM
