Olsen Electronic Ignition M-HBS2-120me S-BH-10113 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 01:46 AM   #1
Olsen electronic ignition M-HBS2-120me S-BH-10113
Furnace will not start on its own. If I tap the relay, or side of the furnace it will fire up and stay running till the thermostate shuts it off. But will not fire up on its own. We had a furnace man come out and he said the relay was toast and probably took the modual out. Told us to buy a new furnace, charged my daughter 160.00 and left. If I tape on the side of the furnace it will fire up. I have looked everything over, leads wires etc, and figure its just something easy but am stuck at tapping the furnace and it will fire up and work just fine. I hold my hand on the gas valve, tap the furnace and can feel the gas valve open and it fires up. Not sure what I need to do.
Jocelynn is offline   Reply With Quote
Old 12-21-2011, 05:32 AM   #2
An old Tradesmen
Rewards Points: 6,132
Determine if its relay, or the gas valve sticking.
One way, is to remove the 24 volt fee from the gas valve, tap on side of furnace, then put wire on. If it fires up, its a relay, if it doesn't, its probably the gas valve.
convert propane pilot to electronic ignition? sonoramike HVAC 4 12-16-2011 04:40 PM
Carrier Cobra circa 1996 w/ electronic ignition ChuckT HVAC 4 11-03-2011 07:36 PM
Boiler with Electronic Ignition Ques roztom HVAC 8 10-12-2009 05:28 PM
Electronic ignition furnace question rcossebo HVAC 4 11-23-2008 02:02 PM
Electronic Ignition Furnace will not stay burning Drennen HVAC 3 12-29-2007 02:20 AM
