Older Unit/parts - HVAC - DIY Chatroom Home Improvement Forum
Old 06-22-2012, 10:55 PM   #1
Rewards Points: 528
older unit/parts
Is there a website that specializes in ac/heat pump parts for older units? (at least 15 years)
hidden1 is offline   Reply With Quote
Old 06-22-2012, 11:03 PM   #2
Missouri Bound's Avatar
Many parts are used in new equipment that have been around that long....here's a link to one supplier.........HVAC Parts Outlet
Do you want it your way or the right way?
Old 06-23-2012, 06:08 AM   #3
biggles's Avatar
most major brand units use a mix of parts just like a car does so they are all availible some with updates especially the electronic stuff.motors,relays limit controls still do the same thing they did 15yrs ago....check here for items and prices.. http://bestbuyheatingandairconditioning.com/
Old 06-24-2012, 09:57 PM   #4
Rewards Points: 528
Ok thanks.
So even if i had a early 80s or mid 90s those sites should have the parts?
Old 06-25-2012, 07:09 AM   #5
biggles's Avatar
sure they will,with the brand you have still being produced in 2012 even www.grainger.com is a good source and should be local to you
Older Romex / NM 14-2 proper grounding Circuit_Breaker Electrical 3 02-08-2012 12:10 PM
Could a older light fixture cause premature CFL light bulb failure? imola ghost Electrical 10 01-10-2010 03:53 AM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-14-2009 11:17 PM
Older GE Fridge no Ice WorldOfJohnboy Appliances 3 09-10-2009 07:39 PM
Question about replacing load center in older house speedster1 Electrical 5 05-14-2009 07:55 AM
