Older Rheem Furnace 1990 Model Rheem Imperial 80 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2010, 06:21 PM   #1
older rheem furnace 1990 model rheem imperial 80
my furnace turns on then shuts off after a few minutes after about 15 seconds the igniter lights furnace starts and repeats itself 3 or 4 times then does not turn on. If I turn the thermostat off then on it will light up and and do the same thing.
twbeach is offline   Reply With Quote
Old 12-07-2010, 07:02 PM   #2
Furnaces shut down when they don't sense flame after several attempts. Turning the stat down then back up resets the safety. If it has a flame sensor rod clean it and the burners. Lots of the older rheems used the hot surface ignitor instead of a dedicated flame sensor so yours might not have one. New updated control board and sensor kit is more then you want to spend on a 20 year old furnace.
Old 12-07-2010, 07:06 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
check for codes also cleaning the flame sensor with steel wool may solve the problem
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Rheem RGFD Furnace Flashing 66 LED sneaky_pete HVAC 4 12-28-2007 06:31 AM
Rheem Furnace No Heat, Help jpellett001 HVAC 1 12-10-2007 10:11 AM
Rheem Furnace jsfjets HVAC 2 12-06-2007 08:00 PM
installing new rheem furnace to old a coil rad488 HVAC 1 10-17-2007 09:07 PM
Furnace won't lite-Coleman Model 900759-Help asstratford HVAC 4 10-18-2006 05:24 PM
