-   -   Older GE furnace not firing up (http://www.diychatroom.com/f17/older-ge-furnace-not-firing-up-84685/)
jax1lightning 10-23-2010 06:23 AM
I have a GE furnace from 1977
Model # BLU 100C93OBO
The pilot light stays lit but the unit won't fire up.
I have jumped the red and white wires on thermostat(nothin) and replaced it.
I have replaced the Thermocouple, Gas valve and Transformer
& checked the high limit switch.
I have 120 V electricity to the unit and 24 v to the gas valve.
I have checked the fusable links all good.
No door switches or flame out switch??
Now what can I do next??
yuri 10-23-2010 07:03 AM
Check the orifices where the gas enters the burners for spiders web/egg sacks blocking them. Apparently that happens in some areas.
kenmac 10-23-2010 09:37 AM
Turn the valve from pilot position to the ON position
yuri 10-23-2010 10:24 AM
It's always the basic things that trip you up.:laughing:
yuri 10-23-2010 10:27 AM
Jax you should get that unit checked by a Pro. MOST of them the heat exchangers are cracked and can produce CO Carbon monoxide. By the time a CO detector blows you have breathed a lot of it in. They are designed/meant for catastrophic failures/blocked chimneys etc.
beenthere 10-23-2010 11:29 AM
LOL... I hate when a new I install has the gas valve turned off, and I don't notice it.
OP. Also, are you checking the 24 volts at the gas valve by reading across it. Or by reading each terminal to ground or common?
jax1lightning 10-23-2010 05:26 PM
GE Unit
Thanks the Unit is cracked so I'm not wasting any more
time on it.
