#1 |
older furnace trouble
I have an older trailor that has a miller furnace with a wayne burner.My problem is that the furnace will run fine but I cant adjust the thermostat I've replaced the thermostat but it still runs nonstop.Does anyone know what else it could be If you can help Id appreciate it. Thanks
#2 |
An old Tradesmen
Disconnect the thermostat, turn the power on to the furnace. if the heat still comes on, you have a short or bad control.
If it doesn't come on. You may have a short in the wires when you mount the stat, make sure wires are insulated and not touching.. |
| Display Modes | |
| Help troubleshooting furnace problem | robert_ | HVAC | 21 | 02-15-2012 09:04 AM |
| Can anyone help me plse? Need an older hammock style 'metal frame' for furnace | Travelgirl | HVAC | 29 | 09-03-2009 08:05 PM |
| Problems with new furnace..Overheating, having to reset. Furnace too big? | Tommy2 | HVAC | 41 | 12-01-2008 02:55 PM |
| New Cased Coil - Install to Furnace - PICTURES!! | hartkem | HVAC | 39 | 11-18-2008 02:45 AM |
