Older Carrier 3-wire Pilot Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 12:56 PM   #1
Older Carrier 3-wire Pilot problem
Having problems with the 3-wire pilot light on my carrier furnace. It started acting up the first time I turned it on this year. Pilot would light, igniter would still be going and the burners would never fire up. Cleaned out the pilot assembly and would still not work.
I unplugged the pilot while it was lit and jumped the white and yellow terminals, burners light and furnace works fine. I figured that the pilot assembly was not working so I replaced it. With the new one in, the first time I fired it up everything worked except the main burners would go out then back on every couple of seconds. But it did take a couple of minutes from the time the pilot lit till the burners kicked on. I shut off the furnace and later when I turned it back on, the original problem happened. Pilot lights, igniter stays on and no burners. Any ideas on what is happening. Thanks
robsvsu is offline   Reply With Quote
Old 10-01-2011, 09:48 PM   #2
HVAC Tech/ Browns Fan
U may have a bad out of box 3 wire pilot or a ground problem. You also may have a crack in heat exchanger that blowing back into it. I had found that couple time but also found had pilot out of the box too.
Tator1076 is offline   Reply With Quote
Old 10-02-2011, 05:43 AM   #3
An old Tradesmen
Rewards Points: 6,112
Dirt in pilot gas line.
Old 10-02-2011, 07:11 PM   #4
Thanks, I will check my grounds and make sure the pilot gas line is clean. I was thinking possibly a bad out of box part. I read about a lot of problems with aftermarket parts.
Bryant 3 wire pilot won't hold janibre1 HVAC 11 10-20-2010 01:43 PM
4 wire problem tchenson Electrical 7 04-04-2010 02:17 PM
Carrier Cobra Gas Furnace Problem carriercobra HVAC 13 12-30-2009 12:47 PM
Problem with Carrier Weathermaker 9200 Chipley HVAC 12 12-16-2008 01:44 PM
Ground Wire Problem ScubaRaven Electrical 11 06-08-2006 03:32 PM
