Old 10-28-2009, 05:50 PM   #1
Post Old York combo Furnace - Customize??
Hey Folks,
Thanks for having me here.. I'm Looking for the YORK techs / pros out there that have serviced these beasts for a few years...
I currently have a 20 yr old horizontal unit located in attic providing service as an air mover / gas furnace / ac combo. (ac coil in front)
natural draft unit......
model / serial numbers read as follows:
- May be "1" or "A"
Model No: P-HBD16N07501B SERIAL NO: BLXP119587
073-03150-012 REV A: MFD1090
Recently the DSI ignitor has gone out and has been a real pain in the arse to track down as there are so many obsolete parts for this generation "2" rated unit. I tracked down the dsi at AMerican HVAC parts.com, after much a debachle meddling around with the ignition control module and testing sequence executions. AC works fine, all sequences work fine at a call for heat except for ignition.
Needless to say, I will install the NEW DSI tomorrow and test. If all works , then fine, I have two control modules to choose from and test anyhow at that point.
I have been wondering, after all this trial and error with obsolete parts , a few things...
1. Can the unit be kept in place and the control / safety parts be swapped out for more up to date parts? (ie: hot surface ignition, draft motor, vac lines, pressure switch, digital control board, flame sensors, etc...)
I see these units all doing basically the same job with more efficient electronic "control and safety" parts that I currently do not have. I think upgrading all the parts would be easier than swapping everything out of the attic and probably having to upen and close up some lathing......
Much appreciated guys!
fedupGC is offline   Reply With Quote
Old 10-28-2009, 08:09 PM   #2
An old Tradesmen
You would just have an old furnace with new controls and safeties.
Newer control board would just have a longer blower delay.
Would still have to use the same temp rated safeties. Along with the same pressure rated pressure switch. Those parts are made for and rated for the heat exchanger of that furnace.
So using newer ones, with different ratings would be a hazzard.
Old 10-28-2009, 08:12 PM   #3
Default none
current unit has no flame sensors.
current unit has no ventilation blower.
ie: 20 yr old York and model number.
so new safeties would be an upgrade, no?
Old 10-28-2009, 08:12 PM   #4
old pro
The furnace is UL, Underwriters Laboratory Certified and AGA, American Gas Association certified for the original parts. Changing them out would de-certify the whole unit and be against the codes.
Old 10-28-2009, 08:18 PM   #5
An old Tradesmen
Nope.
All safeties must be rated to work with that furnace. As that furnace was designed.
Anything done to it. To alter it from factory spec. Is a none factory approved reconstruction.
Which means it loses all approvals from all safety organizations. And your insurance company doesn't have to pay out if anything goes wrong.
Old 10-28-2009, 08:32 PM   #6
Default 10-4
10-4 , ill drop the coin to swap that POS.
...thx... over and out..
More On This Topic
You found the house of your dreams, and all the inspections, mortgage paperwork and contracts are done. It's time for that final walk-through before heading off to the closing. Don't take a final walk-through lightly; it's your last chance to spot... Read More »
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to check your furnace filter. The first thing you need to do is locate your furnace. Now in many houses, the furnace is located in the laundry room which is in the... Read More »
Pull the dash piece. Behind here you have the crossover for the stereo system. Let's move that out of the way. You have your air conditioning components. Here is your heater core. Access in the heater core wiring is right here in this harness. But... Read More »
York PM9 Mod Furnace, Aux Fan Question javan HVAC 20 02-10-2009 10:22 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 03:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 03:45 AM
newmac wood/oil combo forced air furnace questions CowboyAndy HVAC 2 09-22-2008 07:17 PM
York Furnace Leaking.. Please help sidoe HVAC 4 10-08-2007 06:55 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
