Old Wall Thermostat To New Digital Thermostat Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 02:55 AM   #1
Old Wall Thermostat to New Digital Thermostat Problem
I just purchased a Honeywell RTH221B thermostat to replace my old Robertshaw 500-107R thermostat. This is for a gas heater only in an old 1920s apartment building.
There were only 2 wires connected the Robertshaw, one in the O terminal and one in the X.
The Honeywell instructions say to connect the O to the terminal which is fine and to leave the X disconnected. Simple enough.
However, with only the O wire connected, the heat doesn't come on. What am I doing wrong here? Thanks.
steiny is offline   Reply With Quote
Old 02-02-2011, 03:42 AM   #2
An old Tradesmen
Rewards Points: 7,370
Need to connect both wires. Use RH and W.
The Following User Says Thank You to beenthere For This Useful Post:
steiny (02-02-2011)
Old 02-02-2011, 04:00 AM   #3
Thank you so much, beenthere! Just connected the former O terminal to R/RH and the former X terminal to W and it works! I never would have figured that out. You just saved me from a cold Los Angeles night
Old 02-02-2011, 04:07 AM   #4
An old Tradesmen
Your welcome.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Thermostat issues rathipon HVAC 4 01-29-2011 11:46 AM
heat pump wiring problem - new thermostat tygrr94 HVAC 8 01-17-2011 08:18 PM
Exterior brick wall has cracks and moves...is this a huge problem? ConstantChange Building & Construction 3 06-16-2006 09:09 AM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 09:16 AM
