Old Steam Heater - Won't Go On! - HVAC - DIY Chatroom Home Improvement Forum
Old 10-15-2009, 01:49 PM   #1
I have an old Steam Heating System. Recently it just got cold and I tried to turn the system on. Usually I'm good with these types of things, but I'm stuck. Any advice on how to get it on? Here is some of the info I got from the side of the plate.
Manufactured by Burnham Corporation
Hydronics Division
Steam: 15 psi
Water: 50 psi
Min. Relief Vavle Cap: 384
Gas Supply Pressure Max: 10.5 Min: 3.5
mgold is offline   Reply With Quote
Old 10-15-2009, 05:05 PM   #2
newtech's Avatar
Rewards Points: 164
Hydronics Division
Steam: 15 psi
Water: 50 psi
Need more info..... What is it doing? Standing pilot,spark ignition? Is there water in the boiler? Model and Serial #'s would help
newtech is offline   Reply With Quote
Old 10-15-2009, 07:39 PM   #3
An old Tradesmen
Rewards Points: 6,112
Is there water in it?
Old 12-21-2009, 01:42 PM   #4
Rewards Points: 5,336
Hydronics Division
Steam: 15 psi
Water: 50 psi
The thermostat controls the boiler. There are also switches that supply power. But before you start flipping switches or touching the thermostat, check that the boiler has been properly serviced and is ready to operate.
I'm sure that's the part your familiar with.
Ron
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
