Old Slab Duct Work - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 06:53 PM   #1
Old Slab Duct Work
I live in a house with duct work in the concrete slab. My furnace is currently set up as a downflow and I have a humidity problem even in the winter months, especially in the summer. I plan on flipping my furnace to a upflow routing new duct work and abandoning the ducts in the slab. I am pretty confident that I can follow the instructions in the installation manual on changing things in the furnace for it to be upflow. I have some pretty good reference material on designing duct work. My question is what should be done with the old duct work in the slab?
Handy DIY is offline   Reply With Quote
Old 01-31-2012, 07:00 PM   #2
Rewards Points: 13,712
Just leave it and block off the vents.
Old 01-31-2012, 07:35 PM   #3
What material would I use to block off the vent? Subfloor over the vent opening, sytrofoam insulation, what would be best?
Old 02-01-2012, 12:44 AM   #4
I've done the same thing at work. All we do is pour bentonite down the duck, put some 3/4" rock in, and concrete on the top.
Grayguy is offline   Reply With Quote
Old 02-01-2012, 06:17 AM   #5
Rewards Points: 1,216
At each floor register I would fill with stone up to about 3"s from the finished floor the add non shrink grout to level off.
At the heater location I would fill with stone then concrete.
COLDIRON is offline   Reply With Quote
Old 02-02-2012, 08:06 PM   #6
Rewards Points: 156
what about using the old ductwork for return air? you could have return ducts in each room.
av-geek is offline   Reply With Quote
Help with new duct work trunk running to attic from basement. coderguy HVAC 8 10-02-2011 10:22 AM
Duct formed in slab reckless HVAC 2 10-01-2011 08:53 AM
Duct Work Too Small? Dakotamade HVAC 3 09-02-2011 12:34 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
Install new vent/register into existing duct work? Jughead HVAC 11 12-09-2010 05:08 PM
