-   -   Old RUUD Gas heater not kicking on at all. Was fine yesterday. (http://www.diychatroom.com/f17/old-ruud-gas-heater-not-kicking-all-fine-yesterday-163209/)
GrapeApe 11-13-2012 12:06 PM
Hi guys. I am brand new here and found the site through google while trying to fix my heater. Usually when it doesn't kick on it's because I forgot that I had turned off the gas for the summer (it runs about 15.00 a month just for the pilot :eek: ) but this year I was on top of things.
I turned on the gas.
I lit the pilot.
I turned on the heat on the thermostat and set it for 72. The thermostat clicked and the heater fired. All was well.
Then last night it got down to ~30 degrees here and I woke up shivering. I have a house full of kids (6) so this was a big problem. I raced to the thermo to make sure someone hadn't turned it off accidentally. It was fine.
I went out to the furnace to check if the pilot went out after a storm we had.
(click for a larger pic)
http://windypix.com/?dm=S4GD.jpg
It was lit.
http://windypix.com/?dm=QUNQ.jpg
And so then I checked online for other ideas which lead me here. I cleaned the temp/flame sensor with a wire wheel.
http://windypix.com/?dm=YRN8.jpg
Still not good. Then I saw the "jumper R/W" threads and tried that. No cigar.
So I did what all idiots do. I took my screwdriver and poked around a little, wiggling wires and generally making sure everything was connected.
Then I plugged it back in. Still nothing but the normal "hum" and the pilot light hiss.
So I poked in there again with the screwdriver but I forgot to unplug it this time. I happened to tap this thing, which I have no idea what it is. :whistling2:
http://windypix.com/?dm=4X3H.jpg
That's when it seemed to depress a bit and WHOOSH! My gas kicked on and I had fire. Scared me half to death, but the fan kicked on at that point and the house warmed up. It had no problem kicking on after that so I guess it had crud in it or something and my poking freed it up.
At any rate, this post has two purposes.
One, I hope this helps someone else with an old furnace. They are old and don't have fancy lights but darn it if you can't fix them with a bit of bailing wire and some bubble gum!
And two, what is that thing I hit and did I cause myself further problems down the road? :wink:
Thanks! :thumbup:
Marty S. 11-13-2012 06:16 PM
That is a safety device called a flame roll out switch. When the furnace flue down drafts or a big crack in the heat exchanger lets air from the blower come into the exchanger it pushes the heat/flames out the front of the furnace and trips the switch so you don't get carbon monoxide poisoned or burnt. At the very least you'll want a complete safety inspection from a well trained tech. If it trips again before he gets there buy some electric space heaters,don't reset it. Could be just a big gust of wind caused it or could be something seriously wrong. Only way to know for sure is have the furnace tested.
GrapeApe 11-13-2012 06:29 PM
So that's what that is.
We had a huge 12 hour storm so I'd imagine that's what tripped it. We do have a CO detector in the house so we *should* be OK, but being that it's possible it could be bad I'll foot the 70.00 housecall bill and get someone to check it out. Best case scenario we're A-OK :)
Thanks for the info Marty
Doc Holliday 11-13-2012 07:01 PM
If you have a/c have the tech check the evaporator coil as well. Keep that return air filter clean, new. Lack of air flow will also cause that limit to trip.
This is a relatively new system that the same flame roll out switch tripped due to the dirty filter. I removed the filter, reset the switch and it's been good ever since.
http://i87.photobucket.com/albums/k1...k/CIMG1385.jpg
http://i87.photobucket.com/albums/k1...k/CIMG1396.jpg
ben's plumbing 11-13-2012 09:11 PM
wow what a dirty filter doc....did you notice the code violation on the flex connector to gas valve....sell them another repair or red tag it....ben sr
ddawg16 11-13-2012 09:14 PM
Flex hoses are not allowed?
Doc Holliday 11-13-2012 10:04 PM
Ddawg, it has to be steel pipe from the valve to outside of the unit, then a gas drip leg and then to the gas flex line with a gas cock/valve.
Ben, I didn't notice it until you just said something, good eye, but it wouldn't have made any difference, Bank of America foreclosed property. Vacant.
