Old Return Air Plenum For New Furnace? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-25-2008, 09:46 AM   #1
Old Return air plenum for new furnace?
I am replacing my 41" tall, low boy furnace shortly with a Carrier Infinity 80BTU. The Return air duct on ceiling is 10" x 20" fed from the underside by a 12 x 20" X 90 degree turn which offsets sideways from the cold plenum. See attached .This 12 x 20 x 90 degree offset measures a total of 18.5 inches sideways and up 22" to the underside of the duct. The vertical plenum dimension is 19 x 17.25.
The sales rep says he will retain all this cold plenum and offset and simply build a new plenum extension to floor level for the Carrier.
Am I wrong in thinking that a new 2 x 45 degree offset would be a better, more effective transition to the plenum , then down to the floor where it would meet the 4" filter ?
Chemist1961 is offline   Reply With Quote
Old 12-25-2008, 10:20 AM   #2
Your duct is big enough to compensate for the off sets.
hvaclover is offline   Reply With Quote
Tags
furnace , plenum , return air
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Attaching plenum to furnace. hartkem HVAC 6 11-10-2008 02:17 PM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 08:29 AM
Removing Extended Plenum Calm_Blue_Ocean HVAC 15 01-07-2008 05:22 PM
