Old Oil Furnace Supply Lines - HVAC - DIY Chatroom Home Improvement Forum
Old 08-09-2009, 09:41 PM   #1
Project Addict
tjeieio's Avatar
We moved into our home about 5 years and have since replaced the oil furnace with a HE gas furnace. The furnace was fed from an oil tank in our basement with overhead copper lines. After it was removed, I discovered a pair of copper lines previously cut off at the concrete floor. I have since located where the two lines come in through the basement wall then disappear in the floor. There was apparently a previously buried oil tank outside somewhere.
Where the two lines were cut, some oil staining is on the concrete floor. I believe they are seeping old oil, although very slowly. Is there a good way to make sure they are fully drained and permanently sealed at both ends?
tjeieio is offline   Reply With Quote
Old 08-10-2009, 06:38 AM   #2
biggles's Avatar
the tank outside buried in the ground is all yours, also what was the status when you changed to gas?if you dipe the tank and see oil there you might consider having it pumped out and get those lines emptied out...if you ever go to sell that place and a buyers engineer inspection is done that could become a nightmare with selling the house.
Old 08-10-2009, 02:56 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,318
The longer you leave that old tank in the ground, and if it is leaking oil into the ground the more expensive it gets to remove the old soil and eliminate the environmental problem. I would get it checked soon.
Tags
draining oil lines , oil furnace , oil line
Crud in supply lines jenoble99 Plumbing 5 02-13-2009 12:08 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 12:28 AM
Furnace Electrical Supply.... caseywa HVAC 2 12-28-2006 10:37 AM
