Old Oil Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-01-2009, 01:17 AM   #1
old oil furnace
Hi everybody, I have an old oil fired furnace, It will click at the thermastat
but not light or fan blower does not come on. Filter is clean but alot of soot around flue damper. help me
Frederick j Ward is offline   Reply With Quote
Old 01-01-2009, 03:34 AM   #2
An old Tradesmen
Rewards Points: 6,098
Did you run out of oil.
Did you check:
The nozzle.
The electrodes.
The transformer.
The oil filter.
Push reset button once, see if it lights.
Old 01-01-2009, 09:32 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,102
FOR ALL CONCERNED: DO NOT press the red reset button more than once. It may dump lots of raw oil into the combustion chamber and flood it which can result in a major fire if it later ignites! Had a couple customers lie to me about how many times they did that. Had to get the fire dept down for one "incident". Don't lie to your tech either.
Old 01-01-2009, 02:22 PM   #4
Thanks, I will try the reset button ( once ) if it does not work then I will call
furnace repair.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 08:11 AM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
