Old Montgumry Ward Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 04:41 PM   #1
old Montgumry ward furnace
alright so since im without work i agreed to help my friend fix his furnace that has ben sitting off for age's, i plugged in the power and the motor tryed for about 20 seconds then stopped so i took it out and got a single speed motor to the same bracket and all i have 2 wires to connect on that motor and 3 from the furnace a red,black,white and i know its supposed to be high/low/ common for the white i just am jumbled as to how to hook it up it mounts onto the blower beautifuly its just the power i put a new white rodgers and wired it for heat and cool but cool will never be used i just need this guy to start
zrenx is offline   Reply With Quote
Old 12-01-2010, 05:34 PM   #2
HVAC Tech/Owner
Rewards Points: 604
Dude....Montgomery ward? They have been gone for almost 20 years....Most mounts work beautifully on the wrong motor.
Technow is offline   Reply With Quote
Old 12-01-2010, 08:37 PM   #3
Rewards Points: 1,208
put wire nut on black wire, white to wire from motor, and red to other wire from motor, black would be high speed that is used with cooling since cooling wont be used, that wire is not needed
hvactech126 is offline   Reply With Quote
Need Parts for Ward Floor Furnace terryray HVAC 13 10-03-2012 08:49 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Valve For Ward In Floor Gas Furnace faselh HVAC 0 11-17-2010 11:24 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
