Old Miller Trailer Furnace Flame Seems Too High - HVAC - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 08:47 AM   #1
Old Miller trailer furnace flame seems too high
I just bought an older trailer with an oil fired Miller furnace.There is no markings on the burner but I am pretty sure it is a Wayne.I have worked on these furnace over the years (i am definatly no tech) changing tips,adjusting electrodes,bleeding,filters that sort of stuff so i am fimiliar with the anatomy of a miller furnace.
The tip was clogged when i got it (the tip and all around it was full of soot pretty bad) so I pulled nozzle apart cleaned it,put new tip in,cleaned and adjusted electrodes,cleaned or replaced all filters,drained out oil tank and put 50 gallons of fresh kerosene. It fires up with and runs good but when I open the flap and check the flame the tips of the flame are a to the top of the hole.All the other trailer furnaces I've worked you could just see the tips of the flame.
I was wondering if this seems right.What else should I check.
Joe the plumber is offline   Reply With Quote
Old 01-07-2012, 09:40 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,426
sounds like the gph/size of the nozzle is too large. too much oil.
The Following User Says Thank You to yuri For This Useful Post:
Joe the plumber (01-07-2012)
Old 01-07-2012, 07:04 PM   #3
REP
I to think it could be a nozzle problem.It could be the angle is wrong,it could be the pressure is off.If the nozzle was pluged you could have a dirty screen.
The air could be off.If you installed this old unit I assume the combustion air fitting is in good shape.
REP is offline   Reply With Quote
Old 01-07-2012, 10:17 PM   #4
Thanks for the help. It was the wrong tip size.
Old 01-07-2012, 11:12 PM   #5
REP
Good to know that hot torch thinggy is all better now.
Luxaire furnace flame out Tuckrb HVAC 14 01-28-2012 11:00 AM
New High Efficiency Furnace Problem Buster 567 HVAC 8 12-13-2010 09:36 PM
Trane XE 80 Furnace - flame out and restart Thome HVAC 3 10-12-2009 06:27 PM
Coleman Furnace - Flame Goes OUT!!!! mmoniz HVAC 1 03-02-2009 10:23 PM
Miller Furnace Problems Ajournyman HVAC 8 01-16-2008 09:33 AM
