#1 |
Old Kitchen Brick Exhaust
Hello All,
I have a 90yr old 2-story home with an old brick exhaust that currently has a 6inch "flex" pipe inside that is venting the furnace from the basement. I need to vent my kitchen rangehood through the same exhaust...and would like to know if i can tie into the existing "flex". My concerns would be losing the bottom of the flex when i cut into it, tight working space, fire safety (grease into same furnace vent), & pipe size for 500cfm hood. I have been told by plumbers that range exhaust can go down to 3inches...if this is true, I could probably cut a hole into the side of flex and seal it somehow. Is this possible & safe? Any help is appreciated!!! Tks |
#2 |
It's defiantly possible and pretty easy to do.
Unfortunately it's also dangerous and violates every plumbing code. |
#3 |
Can you elaborate? What are the precations, etc...
Thanks for the reply!
#4 |
what is the best roof cap for my rangehood
#5 |
Michael,
I see no way that a range hood and furnace vent should share the same piping. You could get back-drafting of carbon monoxide from the furnance into the home via the range hood line and kill everyone. Can you punch a vent line from the range out the sidewall? Bearpaw: start your own thread please. |
| Display Modes | |
| Kitchen Exhaust Fan | Rick Bruner | Electrical | 5 | 05-31-2013 09:05 PM |
| Complex challenge with bath exhaust fan - need help with solution! | Honest Bill | Electrical | 6 | 11-02-2007 03:52 PM |
| My Kitchen Floor-Problems!!! Please Help!!! | Fat b | Flooring | 3 | 01-25-2007 04:21 PM |
| Making an 8" hole in the brick | Hushpuppy | Building & Construction | 6 | 11-28-2006 08:17 AM |
| Kitchen Cabinets and Walls | ththomps | Remodeling | 4 | 09-18-2006 11:23 PM |
