Old Kitchen Brick Exhaust
Hello All,
I have a 90yr old 2-story home with an old brick exhaust that currently has a 6inch "flex" pipe inside that is venting the furnace from the basement. I need to vent my kitchen rangehood through the same exhaust...and would like to know if i can tie into the existing "flex". My concerns would be losing the bottom of the flex when i cut into it, tight working space, fire safety (grease into same furnace vent), & pipe size for 500cfm hood. I have been told by plumbers that range exhaust can go down to 3inches...if this is true, I could probably cut a hole into the side of flex and seal it somehow. Is this possible & safe? Any help is appreciated!!! Tks |
It's defiantly possible and pretty easy to do.
Unfortunately it's also dangerous and violates every plumbing code. |
Can you elaborate? What are the precations, etc...
Thanks for the reply!:eek: |
rangehood roofcap
what is the best roof cap for my rangehood
Michael,
I see no way that a range hood and furnace vent should share the same piping. You could get back-drafting of carbon monoxide from the furnance into the home via the range hood line and kill everyone. Can you punch a vent line from the range out the sidewall? Bearpaw: start your own thread please. |
If you are just wanting to share the same chase, that would be okay, but to tie both together is inviting a CO disaster into your life.
| All times are GMT -4. The time now is 10:33 AM. |
