Old 02-28-2010, 01:06 PM   #1
Question
old house no ductwork
how do you go about adding hvac ductwork to an old house wich had boiler/radiator heat? this house is on a slight crawl space but is very difficult to access crawl space, plus it has multiple peaks so no continous access to attic. any help would be great.
kenl69 is offline   Reply With Quote
Old 02-28-2010, 01:29 PM   #2
Hvac Pro
Where do you live? Is your electricity reasonable in cost? how much per Kwh. How big is the house. There are minisplit heatpumps and other heating options for heating and cooling rather than forced air.
Old 02-28-2010, 03:37 PM   #3
An old Tradesmen
Your question is hard to answer without seeing the house.
Depends on how big the crawlspace is. And how easy access to it is, or isn't.
Old 02-28-2010, 07:11 PM   #4
Senior Tech.
My daughter has 10 foot ceilings. I ran exposed spiral. I had seen it done on one of my calls and thought it looked cool.
It takes some getting used to, I guess. It is a conversation piece.
Milk man is offline   Reply With Quote
Old 02-28-2010, 09:14 PM   #5
Might want to look into a unico system.
Old 02-28-2010, 09:22 PM   #6
Learning by Doing
Leah Frances's Avatar
Also consider mini-splits. These are commonly used in 'old house' applications. We considered the Unico and are going to do the mini-splits instead.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-03-2010, 08:25 AM   #7
Question
this is a 150 year old 2 story house with 4.5 bedrooms upstairs and a full bath and laundry room, and eat-in kitchen and livivg room and office/5 bedroom downstairs. the crawl space varies in depth from 2 ft. to nothing in spots. the upstairs has been added to twice so the attics are not accessable without major cutting and re-stucturing. this all used to be plaster and lat, but has been re-done downstairs. what are mini-splits? electricity has just doybled in price in ohio, so would prefer to avoid elec. if possible
Old 03-03-2010, 06:54 PM   #8
Hvac Pro
Google air to air heat pumps for more info. Minisplit is a type of A/C and can be bought as a heat pump combo also:http://www.fujitsugeneral.com/wallmounted9-12RL.htm
Old 03-05-2010, 05:55 AM   #9
A system I've installed which works well in your application is to install the furnace/coil in the basement below an unused closet/ and or space on the first floor where a plenum can come up through the floor (corner area of large room?) , then shoot off one large (or opposite directions depending on layout) rectangular ductwork along the inside wall to feed all of the upstairs rooms and catch the downstairs at the ceiling levels. Once the rectangular is framed in and drywalled (headered)...you can just cut out the duct openings for the downstairs and install the register boots. Depending on where the rooms are upstairs...it can pose a challenge to running ducts to those rooms. A lot of times though...the rooms at the farthest end of the rectangular ductwork(s) can be installed with round duct running along the front wall and headed off also.
If you don't have any basement, or it's in an inconvenient location...about the only way this application can work is in an unused closet, then you can use the walls on both sides of the closet as returns to the furnace. The upstairs would obv need a separate return air ran.
Affordable7 is offline   Reply With Quote
My house's previous owner - DIY horror stories Leah Frances General Discussion 118 03-14-2013 02:27 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
