Old Holly Lear Siegler Gas Furnace Switch Location - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2011, 09:29 PM   #1
Need some help related to locating a "switch" on or near a gas furnace. Its an old Lear Siegler 120000 btu natural gas input...heater. I believe the model number is IGA12CD14 (probably original 1960s, when house built). Well, the Gas company guy came to inspect the heater and told my wife (her words) that it was working fine but that there was a switch that kept on falling back to the Off position and, he continued, frankly, "I'd just call a handy-man to tape the thing on the ON position. Well, that seemed a little weird to me...but that was two weeks ago and now its 28 degrees outside and I NEED MY HEATER! haha... I went into crawl space and cannot find anything even remotely looking like a "switch" that falls back into the off position. Does anybody have any suggestions that don't include the words: get a HVAC technician or Get a new one? Thanks guys.
Siankaan9 is offline   Reply With Quote
Old 11-05-2011, 09:33 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
call an electrician. Ha!
look for a light switch. follow the main power wire back from the furnace.
Doc Holliday is offline   Reply With Quote
Old 11-05-2011, 10:37 PM   #3
how
Rewards Points: 1,104
It would usually be near the entrance of the crawlspace. It will look like a light switch. Usually it will be near the ceiling. If it's not there then follow the 120 V line from the furnace and it will lead you to it( as Doc says).
After you've turned it back on and heated up the house, I'd replace that switch since something is wearing out inside it.
how is online now   Reply With Quote
Old 11-06-2011, 05:17 AM   #4
biggles's Avatar
should be 2 switches one with a red cover emergency as you go up into the attic then a service lightswitch for shutting the furnace down at the furnace tape both up..to check power is up go to the stat and put the FAN in ON position if you have cooling on that stat
Old 11-06-2011, 12:26 PM   #5
how
Your gas company checks out heating systems? Ours requires the smell of gas (bad publicity) to move them beyond a "call your gas contracter" response.
When you said crawlspace.. did you mean under the house or the attic?
In our neck of the woods, the red faced shut off switches only seem to have been used for houses that had oil heating systems that were then left in place when folks switched over to gas. We view any of those ancient switches as a likely cause for furnace power loss.
Old 11-07-2011, 11:13 PM   #6
Yeah, they (gas co.) just come out to do a light inspection around these parts. Maybe they'll light some pilots, and that kind of stuff.
And yes, crawl space is under the house. And I just went back down there and there aren't any switches at all. I've followed all electrical lines and each and every conduit, and nothing. I wonder if I can post pictures here, do you know if I can?
Thanks for your help guys...this is pretty frustrating.
Open pressure switch on furnace Dale0202 HVAC 4 01-26-2011 10:35 PM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 03:27 AM
Lear Siegler G350SW80 cover Steve Burke HVAC 0 05-25-2010 04:31 PM
No emergency cut off switch on my furnace Red Squirrel HVAC 8 10-13-2009 07:09 PM
Furnace Transfer Switch... caseywa HVAC 16 02-18-2008 09:14 AM
