Old 06-08-2010, 11:49 PM   #1
old furnance blower
I have an old furnance blower that I want to use I know the white wire is common and the numbered connection are the different speeds there are 2 brown wires coming from the motor to the start/run cap. when I connect the white and red wire to power the blower hums if I give it a little push it runs so do I need another connection to the cap? or does the wiring look complete and the cap could be bad?
elbruceo is offline   Reply With Quote
Old 06-09-2010, 06:10 AM   #2
An old Tradesmen
old furnance blower
Wire on right isn't connect to capacitor.
Connect it. And should be fine, if capacitor is good.
Old 06-09-2010, 01:53 PM   #3
old furnance blower
It is connected to a spade connection there are 3 connection points the one with no wires has 2 spade connections the one on the left w/wire has 4 and has a red dot next to it and the other one (that look disconnected) w/wire looks like its connected to the case
Old 06-09-2010, 01:55 PM   #4
An old Tradesmen
old furnance blower
The one connected to the case. Should be on the one that has no wires on it.
Old 06-09-2010, 02:05 PM   #5
old furnance blower
thank you
it work after moving the wire
Bryant Plus 90 - No Blower Ducaticorse HVAC 11 10-16-2012 09:39 PM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 05:48 AM
Comfortmaker blower problem rerobins HVAC 2 01-06-2010 11:38 AM
Furnance blower fan Noise! rosco HVAC 4 12-28-2009 10:03 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
