Old Furnace Vent From Crawl To Roof - HVAC - DIY Chatroom Home Improvement Forum
Old 08-26-2011, 11:13 AM   #1
Rewards Points: 206
Question
Old furnace vent from crawl to roof
We are going to put a new roof on our one story brick rancher. There is a gas furnace exhaust vent that goes from the crawl space up through the roof.
The furnace is not there anymore, so this is just connecting air in the crawl to air above the roof.
I want to get the roofer to remove the part above the roof, patch the hole and put the new roofing over it.
What should I do with the rest of the duct? Leave it open at both ends? Close one or both ends? How?
I'd rather not remove the duct entirely because then I'd have to patch holes in the ceiling and floor. The duct is in a bedroom closet.
John_W is offline   Reply With Quote
Old 08-26-2011, 11:37 AM   #2
Experienced
Jackofall1's Avatar
Have the roofer install new decking and shingles, you may cap either end. With one end capped there will be no flow.
You should think about removing it just from the stand point of the gained space you will get.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
John_W (08-26-2011)
Old 08-26-2011, 12:08 PM   #3
Busy DIYer
picflight's Avatar
Rewards Points: 150
I am in the same predicament, I removed a water heater and am now contemplating removing the Transite vent and using the roof opening as the vent for the bathrooms.
As suggested by John, just the space gain in the closet would be nice.
picflight is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Adding new furnace vent in basement campbellp HVAC 0 12-11-2010 08:41 AM
Remove Pipe Vent from Asphalt Shingle Roof WaldenL Roofing/Siding 5 09-26-2009 01:46 PM
abandoned furnace roof vent DangerMouse Building & Construction 4 02-04-2009 12:46 PM
hip roof vent pinkertonpv Roofing/Siding 10 10-07-2008 06:58 PM
