Old Furnace Igniter Sparks But Pilot Does Not Turn On - HVAC - DIY Chatroom Home Improvement Forum
Old 01-05-2011, 02:18 PM   #1
Old Furnace Igniter Sparks but pilot does not turn on
I have problem with old furnace. Igniter sparks but pilot is not turning on.
Control model is SU8610 and Gas Valve VR8440P2088
I already changed Pressure switch and control penal.
Chak641 is offline   Reply With Quote
Old 01-05-2011, 04:13 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
Post furnace brand name and model and serial #.
Old 01-06-2011, 08:03 AM   #3
Furnace is made by Sears Kenmor I will post Model # NUGE080KG02
Now furnace turns on but when blower turns on burner goes off or does not stay long.
any solution.
Thanks I realy appreciate
Old 01-10-2011, 10:38 PM   #4
any solution.
Old 01-10-2011, 10:47 PM   #5
HVAC / Plumbing
Tempstar / Heil made some of their furnaces. Make sure you have enough air flow. Burner could be cycling off on limit due to improper air flow
kenmac is offline   Reply With Quote
Old 01-11-2011, 10:42 AM   #6
Flame does not stay long enough
Burner turns on but when blower turns on either burner turns off and start from pilot light and then on again but blower stops . Same again .
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 03:22 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
