Old Furnace Fan Blowintg 24/7. Wiring Question. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-12-2011, 06:18 PM   #16
I found it here and these guys seem to have a better reputation.
http://www.partsguy.com/cgi-bin/PartsGuy/L36847.html
If there is a problem with physical fit, is it acceptable practice to construct a metal adapter plate or similar?
grantb5 is offline   Reply With Quote
Old 09-28-2011, 11:49 AM   #17
OK I installed it and it seems to work. The new one had 4 wire terminals, two (optional) of which had something to do with the thermostat. In my case I just went with the original wiring where the fan runs on heat it senses only. BTW the box calls it a CAM STAT whatever that means. There is a better photo of it here out on the web:
And here too: http://www.furnacepartsoutlet.com/pr...93417_zoom.jpg
So regarding adjustment... I think the fan runs a little longer than it should at the end of the heating cycle. It tends to blow a little cool-ish air before it finally shuts off. The temp is set for 95 out of a range of about 90 to 120. That's how the old one was set(95). So should I raise the dial a bit to say 100?
Educational link for self, included for posterity: http://toad.net/~jsmeenen/blower.html
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Question about light in furnace rm Sherpa Electrical 7 12-22-2008 08:10 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
